Question about Canon Cameras
I have a Canon YH 19x6.7KTS 19:1 Motorized lens unit, how could i fix this unit
How do I get my camera lens unstuck?a
You are in ticklish situation. The motorized assembly for the lens is apparently in need of repair. If you attempt to unstick it you might just strip the gears further.
Not a cheap repair since working on those miniature camera is labor intensive and the parts are proprietary and expensive.
Might be better to just get a new unit given the high repair cost.
Mar 13, 2016 | Kodak Genuine Easyshare C1450 Lens And Ccd...
Our Canon EOS Rebel XSi no longer works on auto focus. The flash works but the camera just makes clicking noises and the screen says "busy". Any suggestions? The camera works fine in manual...
Optical focus relies on a gear driven motorized system to focus the lens. It sounds like the drive is either frozen by a foreign object (it doesn't take much) has gotten into the system, or a tooth has worn/broken on the gearing.
Try taking the lens off and blowing the camera out with some canned air. If that doesn't do it, it's a trip to the repair center.
Jul 04, 2011 | Canon EOS Rebel XSi Digital Camera
I'm plan on buying a 70-200 2.8 len do i really
They're most definitely not the same lens, even discounting the Image Stabilization feature. The L has 18 elements in 15 groups. The IS has 23 elements in 18 groups. There's also an IS II, which has 23 elements in 19 groups.
Look at http://www.usa.canon.com/consumer/controller?act=ProductCatIndexAct&fcategoryid=150 and you can compare them yourself.
Jul 08, 2010 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
I am looking for a schematic for my quantary 19-35 lens
It's the same lens which is also marketed with the names Tokina, Vivitar and Cosina. It's a very old lens design and has been manufactured as both a manual focus and autofocus variant, so choose the right one.
You won't find a free repair manual with parts diagrams for it as it's still copyright material, but if you look on your favourite search engine you'll find a few companies who'll supply the information for a fee.
May 26, 2010 | Quantaray 19-35mm F3.5-4.5 for Canon
Lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nov 05, 2009 | Canon PowerShot SX100 IS Digital Camera
My canon L1 Hi8 has a LENS error message on the screen how do I fix it
According to what I find, the 'LENS' message means that either there is no lens mounted, or that the lens is not mounted correctly. The camera is only compatible with VL lenses, which are identified with a "VL" mark. If you're sure you have a compatible lens, and the lens is mounted correctly, you probably need to have the unit serviced. I'm not really sure where you might find a shop that services that model though.
Sep 16, 2009 | Canon Video Cameras
Help! Dropped my Candon Powershot SD600 Digital Elph.
replace the motorized lens and you should be ok. You have to buy a duplicate Parts camera from Ebay to have the part to fix yours.
Mar 15, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
