Question about Kitchen Ranges
I have a Oil Fired Rayburn 669k that is very noisy when the burner is working, it also has a loud whistle that is very annoying. Can the noise levels be reduced or is this a case where Rayburn have designed a system to maximise on efficeincy at the expense of the noise level.
SOURCE: fan noise
I was having the same problem and I just fixed it yesterday. You will never guess what was causing the loud fan noise.... give up? the NVIDIA Quadro Graphics Cards that were in there...... I bought an ATI Radeon 3870 yesterday popped it in, installed the drivers, and now my computer does not sound like an airplane anymore....... this card is amazing and its on newegg now for 80 bucks..... itds GDD4 as well and the games look better than a playstation 3........ this card also improved my overall system performance drastically.....
Posted on Jan 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
mrgreenz
  • 962 Answers
SOURCE: oil light, noisy engine
What type of noise does it make. check if it has "blowby" . Blowby is when there is air coming through to the fuel system. It means that the rings , bearings , and other critical components are bad.The engine needs a complete overhaul or a new engine block. Maybe even the heads. if's it's a ticking, clicking kind of noise it is the valve lifters or rocker arm problem.such as the valves.
Posted on Feb 06, 2009
devilraptors
  • 21 Answers
SOURCE: Sony Vaio laptop fan is very loud and continously running
My pcg-k33 was very noisy (fan) so I vacuumed the fan opening with a powerful shop vac. This helped alot. I think that the CPU temperature triggers the fan so keeping the cooling system clean is important. As well, there are openings on the bottom for air so it is important to keep the unit on a surface that doesn't impede airflow (on your lap is a bad idea)
Posted on Mar 17, 2009
SOURCE: 2003 vulcan 750-how/where to check engine oil level / noisy
there should be a little window just below the oil fill area that says high and low, that's where you gauge the level of oil you have. it's not a dipstick, and not very precise, but that's it.
Posted on May 05, 2009
Why is this Pool heater making a very loud whistle sound after heater is fired up.
sounds like a leak in the air stack or if coming from gas valve need new gas valve
Aug 28, 2014 | Sta Rite Pool & Spa
Radiators go cold after cooking programme ends
Sounds like this is wired in to the oven think you could be missing a link (elec link ) on the rayburn , try the aga rayburn web site they do have atech line
Jan 08, 2013 | Heating & Cooling
My Dyson 07 still seems to be working fine but it just started making a loud whistling noise. I looked for any air leaks but cannot locate any. The whistling noice is quite loud and annoying. Are we doing...
Sorry to hear you're having difficulties with your DC07. If you've been unable to locate the source of the whistling noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
We have just bought a brand new 480cd gas rayburn boiler/cooker and it is making a very loud constant whistling noise. When the cooker part only is on there is no noise but just when boiler is going
This can be caused by several things. Incorrect Gas to Air mixture in the burner air intake valve. . Debris in the gas line to the boiler. To high a gas pressure. Depending on whether you installed this unit or not, will determine if you should try to repair or troubleshoot these issues. If it was professionally installed call the company that installed it. The only one you can't troubleshoot is the gas pressure. That needs to be done by a certified gas technician.
Hope this helps steer you in the right direction to solving the problem.
Mar 15, 2011 | Heating & Cooling
Strong smell of burning oil from chimney of rayburn
the replacement burners seems to not to be set up right. the chap should have had a analiser to make sure the settings are right.you need to call in a pro with the right kit and someone who knows how to use it. your cooker can kill when running like this do not use it
Feb 26, 2010 | Kitchen Ranges
Alpha oil fired cooker (aga type) & central heating breakdown.
you dont say but i presume you have an early model 1996-2000. these had the most horrid burners ever. its wasnt untill later when the ecoflam burners were used that problems that you describe were elimanated as a standard every day problem. better still was the much later 800 series ecoflam twin burn as fitted in the rayburn 800 series this is the aga company that closed down the alpha and now produce the same cooker with better burners.
www.topoftherangeltd.co.uk who can suply used and new burners for you
Dec 25, 2009 | Kitchen Ranges
High running costs for gas fired Rayburn central heating
these are now a redundant range parts are no longer available and a good thing too as they cost the earth to run. gas ones cost more to run than oil. try "top of the range ltd" for a solution
Dec 20, 2009 | Kitchen Ranges
Could you tell me if an oil fired rayburn will run ok on red diesel, I live in spain and kerosene is not available. thanks peter williams
if it is wick burner it will not work. if it is a single pj a gas oil burner can be fitted that will work. if a twin pj then it will work if you turn up the fuel pressure to 12 bar
Nov 29, 2009 | Kitchen Ranges
Loud wizzing/whistling noise
try and look at the belts, if they are wore out replace them
Oct 26, 2008 | 1995 Nissan Pathfinder
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
