Question about Nokia 5200 Cellular Phone
My phone's kepad and the navigation key(except the center key) is not working wat is the problem with it some 1 help me plzz
    Sergeant:
  • 194 Answers
You need to change the inner Keypad strip to rectify this problem.
It may cause around 7-8 dollars only.
Posted on Sep 30, 2010
My nokia 5130c kepad is not properly working that the key is 6,9,# is not properly working
Thanks for writing Fixya. I am Marion and let me help you with this.
There are reasons why your phones keypad is not working, first, have you tried re aligning your keypad if it fits exactly on the button, also, you may try pressing the keys without the keypad tofind out if the problem is just on the keypad or on the phones hardware already. Also, the keypads functionality may affect if it had a water spill or had dropped previuosly.
Jun 24, 2011 | Nokia 5130 Cellular Phone
How can reset my motrola razer v3x without secret code plese help me
Hello, You can perform a master reset to dissolve any glitches, bugs or other complications you experience with a Motorola Razr V3x. According to the device's user guide, a master reset will reset all options in the phone, with the exception of the "unlock code, security code and lifetime timer." Back up any data, pictures, or contacts you wish to keep before performing a master reset on the Motorola Razr V3x
1 Navigate to the "Settings" menu using the directional arrows. Click the "Setting" option with the "Center" key on the phone. 2 Press the "Center" key to choose "Initial Setup" from the Settings menu. 3 Press the "Center" key on the keypad to select the "Master Reset" option from the Initial Setup page. Thank you for using Fixya
Dec 28, 2010 | Motorola Mobility RAZR V3x Cellular Phone
MY I 4 GOT THE CODE AND NOW IT SAYS IPOD IS DISABLED CONNECT TO ITUNES AND I HAVE A NEW COMPUTER SOOO WAT DO I DO CAUSE I CANT PLUG IT IN TO THE SAME COMPUTER I DID IT WITH CAUSE I DONT HAVE IT I NEED...
1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Sep 29, 2010 | Apple iTunes
Everything works except the three bottom keys on the top slide. i.e the menu key, the navigator key and the clear key.
better have it check with your nearest nokia wireless center,i have  the same problem with my nokia n70,it juse needs allignment.
Aug 21, 2010 | Nokia 6110 Cellular Phone
The navigator 6710 won't work as a phone only the navigation switches on. When you switch it on the screen does not show the menu or the contacts. Noen of the keys work except the start for navigation.
amazingly the auto zoom in out is not a software problem.. it's hardware problem nd that's is why nokia is not getting in to help as its gonna cost it alot. the problem is that the upper portion has become touch sensitive. the acceot key , hang up key,the two selection keys and the navigation keys are made touch sensitive "delibrately" or intensionly.
Feb 03, 2010 | Nokia 6710 Navigator Cell Phone
Accidently changed my language feature to spanish -can't figure out how to change it back to english-please help
Change the display language from English to Spanish or vice versa using the
Language menu.
1. From the main screen, press the Center Select key ( ).
2. Use the Navigation wheel to highlight Settings & Tools and press the
Center Select key ( ). (It's the last option)
3. Press Phone Settings, #5
4. Press Language, #4
5. Use the Navigation wheel to select English or Español, and press the
Oct 22, 2009 | Verizon Communications Samsung Juke Cell...
Navigation and back keys are working wrong
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
May 11, 2009 | Sony Ericsson W700i Cellular Phone
6600 kepad problem
in my 6600 the keys are working fine except ok key what could be problem
Aug 14, 2008 | Nokia 6600
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Apr 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 5200 Cellular Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
