Question about HP P5750-69001 - System Board/P4 Motherboard
Cpu fan not detected system is halted - HP P5750-69001 - System Board/P4 Motherboard
3 Suggested Answers
SOURCE: hp dv2000 error code 104- unsupported wireless network device detected system halted
The user has not described the operating system in use.
However this problem generally occurs due to incompartible hardware. in this case it is ever stated. ie. Network interface Device. I suggest you disconnect the Network devices including cables, then try to reboot.
If not descibe how far the booting process gets and type of network hardware connected and operating system to your system
Heruless
Posted on Nov 07, 2008
herminio_hal
  • 210 Answers
SOURCE: cpu fan can not detect when boot at hp dx 2300
YOUR CPU FAN MIGHT BE VERY DIRTY OR IS NOT WORKING. YOU MAY CLEAN THE FAN AND HEAT SINK. AFTER CLEANING AND YOU TURN ON THE THE PC AND THE FAN DIDN'T WORK YOU CAN BUY THE CPU FAN TO A ELECTRONIC STORE SUCH AS FRY'S ELECTRONIC'S. HOPING THIS INFORMATION WILL HELP YOU SOLVE CPU FAN PROBLEM.
Posted on Aug 14, 2009
Alert! heatsink not connected and system halted
well YEAH! the cpu has overheated because the heatsink and/or fan over the cpu has to keep it cool. if it overheats(easily done), your system will stop and it won;t start if the fan does not spin. fix the fan/heatsink. it possilby could have killed the cpu too? not sure.
Nov 18, 2013 | Dell OptiPlex GX620 PC Desktop
Alert chipset heat sink not detected system halted dell xps 420
Sounds like your heatsink which is inside the computer and sits on top of the CPU is bad. There will probably be a fan that sits on top of the heatsink.
Look on ebay and purchase one for your system.
http://www.ebay.com
I found a new one below on ebay for $14.95 (the link is below)
http://www.ebay.com/itm/New-OEM-Dell-Dimension-9100-XPS-420-430-Heatsink-Assembly-XP850-/350520689627?pt=LH_DefaultDomain_0&hash=item519ca943db
May 12, 2012 | Dell XPS Computers & Internet
On boot up on my Dimension 3100C I receive the following error message: Drive 1 not found:Parallel ATA, PATA-0 (PRI IDE Master) Alert! chipset heat sink not detected System halted!
first off your going to ewant to hit f2 or f12 to get into setup and you are going to want to change boot oder to your hard drive. i then would open the comoputer up by taking the side of the case off and checking your cpu. u are going to wanna make sure there is a heatsink or fan securly on your cpu. if not this could over heat and burn your cpu up. heat sinks look like thisbadboy616.png
Jan 07, 2011 | Dell Dimension 3100 PC Desktop
My system only boots as far as the initial bios screen where it says Press F1 or Delete for setup and just hangs there. The keyboard indicators light up, but it will not boot any further.
Good Morning!
and wish you a Happy New Year2011.
1. Visual checkup of the Motherboard: See for any defective capacitors on the board near Processor. A defective capacitor will have a tapered surface and a good one will be flat, on the top. You need to service motherboard. Most of the motherboards carry 3-years warranty.
2. RAM problem: try to put your RAM chips in another slot if vacant. if you have two slots and both are occupied, then try starting system, by placing one RAM at a time and in each slot alternately.
If any combination works then you can make out if and whether your RAM or its slot is faulty.
3. Hanging due to overheating: Before you get the message "Press F1....", pres PAUSE key several times, it should halt the process and the message will not be displayed. This will make sure that the system is halted by pressing the PAUSE Key. After one minute, release pause by pressing any other key and see if you can move further. There may be two possibilities . . .
a) If you are still in the same position, where you have paused the system. The system is halted due to CPU over-heating. Clean the CPU fan with blower or a vacuum cleaner. See, if all of the locks of the CPU FAN and the heat-sink are intact. If the fan itself is not rotating, check for the fan cable and if it is OK, then try replacing CPU Fan.
b) You have reached the same point where it used to stuck before, i.e. at "Press F1...". Now this means your system has halted while detecting other peripherals or add-on cards.
i. HARDDISK: Most possible cause is your HARDDISK is making "click-click" sound and not getting detected. Switch off system and remove all HDD cables (Power and Data both). Start your system and see if you get any message like "insert system disk" this means there is problem with your HARDDISK. the same problem may be caused due to CDROMs. try same and try again.
ii. SMPS POWER SUPPLY: This symptom may be caused due to inadequate power supply. You can change SMPS and make sure if the problem is due to power supply.
iii. ADD-ON CARDS: Remove any add-on card like, Sound card, Graphics card, Modem and switch on the system. if system starts, then turn-off PC. Try placing one card at a time. and start system to make out which card is making the problem.
If the problem remains, get back to us.
Have a nice day!
Jan 03, 2011 | Mercury KVM800M Motherboard
CPU Fan Error. System Halted in asus P5SD2-VM
(CPU fan error, system halted). This is a safety feature so as not to fry the CPU.
Odds are the that the CPU fan either real dirty or the fan is going bad which means you'll need to replace the heat sink assembly.
You can buy an OEM CPU heat-sink assembly, see below.
http://www.xpcgear.com/in3.html
See page 1-11 to 1-12 in your manual.
CPU Intel socket 775 (removing). See video below.
http://www.youtube.com/watch?v=1PyU00K1sKw
If you need more help submit your question here.
Take your time this is not something you rush through.
Cheers'
Mike
Sep 23, 2010 | Computers & Internet
Alert chipset heat sink not detected system halted error message
It is NOT the CPU fan! There is a heatsink over the northbridge chipset adjacent to the CPU. The clip that supplies pressure to maintain contact between the northbridge and the heatsink has detached on one or both ends. There are wire loops at each end of the clip which feed into the motherboard. When the clip detaches (solder failure), it pops the loop out of the motherboard. The BIOS recognizes this condition as a heatsink failure, hence the error message.
Jul 10, 2009 | Dell Dimension 4600C PC Desktop
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Computer won't run
You may just have a fan not spinning fast enough to cool the CPU. Turn off the PC. Open the left side cover and look at the CPU fan and see if it is full of dust. You may have to move the green covers out of the way. Get a can of compressed air and blow the dust out of the fan. Hopefully the CPU hasn't completely overheated and failed.
Good luck.
Mar 14, 2009 | Dell Computers & Internet
ALERT!CHIPSET HEAT SINK NOT DETECTED,SYSTEM HALTED!>
did the cpu cooler fall of? did a fan stop working? perhaps you should open it and have a look- obviously something is overheating. We need more information than this.
Jun 29, 2008 | Computers & Internet
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
HP P5750-69001 - System Board/P4 Motherboard Logo
150 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
