Question about Whirlpool Duet GHW9150P Front Load Washer
Door wont close
I found advise you gave to another as how to manually release the door lock. My problem is that we can not close the door and since we had to just pull the door open without manually releasing it (i hadn't found this place yet) we are now trying to close it and it won't close.
There seems to be some type of black tab in the middle of the latch on tub that looks like it is in the way. Can you help before I call the repairman and spend at least 150.00 on this?? Thanks! cherie
  • bcrstanley May 28, 2008
    Thanks, part has been ordered but it will take 2 weeks to receive--my husband will TRY to fix it. I'll be sitting there reading step by step. I might be back on asking for advice again. Thanks so much, Cherie
  • bcrstanley Jun 06, 2008
    Thanks, it worked!!! This will now be my new favorite site when I encounter problems. Thanks so much for the help jsrock516!
  • 5,911 Answers
I just posted a solution for you on your previous post. I understand that your door will not close. The door latch has probably been damaged. You can try locating the manual release on the door latch assembly and pulling it to see if it resets the latch. Follow this link to see how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If it doesn't reset, you will need to replace it. Use the link I provided to you previously for the instructions on replacing the door latch. A replacement latch costs approx. $43 and can be repaired by YOU. It's not a difficult repair job at all. You can save quite a bit if you read the instructions I have posted and do this yourself. Don't get discouraged, if you need help I can guide you.
Posted on May 25, 2008
  • Jeff Rockwell
    Jeff Rockwell May 28, 2008
    Do Not hesitate to contact me if you have any problems, or additional questions. For a quicker response, you can go to my profile and use the "ASK ME" feature. Good luck and let me know how everything goes.
  • Jeff Rockwell
    Just in case you no longer have the instructions on how to replace the door latch, I'm reposting the link here:
    http://www.fixya.com/support/r587965-doo...
I have a 95 saturn 2 door, the passenger door is stuck closed. The power lock triggers but still wont open from inside or out. Please help!!!
This usually works.
Take a rubber hammer,roll down the window,then manually unlock the door using the inside unlock button (not the power lock button) while you give the door a good whack about half way down where the door lock assembly holds the door closed to the car body.It may take a few whacks and a few lock/unlock cycles but this usually allows the lock to release and you can open the door.NOW.....take off the door panel and lube that lock assembly and don't close the door unless the lock can be locked and UNLOCKED.
Apr 20, 2017 | Saturn Cars & Trucks
Why is my duet whirpool washer door not cycling through. It seems locked open
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism. I found this at the Appliance Guru website.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Extirier door handle broke and has child lock on
You may be able to release the door by putting the window down and unlock. then us a screwdriver to press down on the latch release shown red circle in diagram attacked. 3e51e720-3073-4d93-8f31-498f9e0cc85d.png
Here's a video of handle replacement for an earlier model, but should be close to the 2007. https://www.youtube.com/watch?v=bUV6BZfVxDY A owners manual can be found online at 31SDA6421 Unlinked 2007 Accord 4 Door download page 78 talks about the child-proof lock. parts ilistration can be found at Honda site Honda online store 2007 accord rear door locks outer handle parts
Also video producer also sells parts for Hondas.
May 26, 2014 | Honda Cars & Trucks
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
Citroen saxo 1.1 driver door will not open
hi drivers, i am looking into the same fault for my mums Saxo forte. there are three problems as well as the post above about the child lock. (on drivers door, remove the trim panel and cut the poly material away on the end near lock. look in to the right and with the 3 T30 size torx bolts removed, carefully tilt the lock towards you so u can see the white plastic.) the child lock is at the bottom. mums wasn't stuck so i looked further into it and found the handle mechanism to be jammed and broken. this has a linkage rod that needs replacing for a few pounds from Citroen. You will need a 4 mm drill and a rivet gun to change door handle. i fixed this and now door opens and closes and will work with the key. but door wont open from inside using the pull lever. looking closely at the top right of the lock unit check make sure the long link rod is connected at both ends, i have now found that there is a spring or connecting bit that allows the door to open from in car. i am trying to find the right part for this without replacing the lock mechanism at around 70. wen i find this and the door works fully again i will post the fix method.
Jul 09, 2012 | Cars & Trucks
Power door locks stuck wont release 1989 toyota camry help....
sounds like the lock might be corroded. or the actuator is faulty might have to pull the door panel while the door is closed & try to get the lock to release.
Good luck
Dec 02, 2009 | 1989 Toyota Camry
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Quad cab rear door closed and wont open
what you have to do is make sure door lock is in unlocked position put a flash light inside the door to see you need to get a screwdriver into the release spring area try to pry up on the hook area that flips over the piece thats mounted to the door jam it should release sounds like you need to spray wd or blaster in the lock assembly return spring not kicking back
Sep 11, 2008 | 1998 Dodge Ram 1500 4WD
Whirlpool Duet GHW9150P Front Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
