Question about Cycling
I need speedster rhode gear shuttle car rack instructions, the rack is about 5 years old
I can't find instructions, or a manual on a Sportrack Bike shuttle rear bike rack, says model number is A1124, and in smaller letters/numbers below is QS1124. any help?
Just Google brand/model, look for videos or even just pics that show it mounted. Rear racks are similar, not all that complex, so even a similar model instructions or video should be sufficient. Or just contact the manufacturer, found in a simple Google search for the rack: Contact Us SportRack US
Apr 14, 2017 | Sportrack Cycling
Steering angle sensor resetting
Have to reset the angle sensor, I would guess
Have to check for codes & data with professional scanner,
in enhanced mode
If you changed the rack, it has to be aligned,the shop should
do what is necessary
A 5 year old vehicle should not need any of that work for years
---so why are those parts worn out?
You do both lower ball joints, not one side,like when you do a
wheel hub bearing, you do both sides
Mar 26, 2014 | 2008 Jeep Patriot
I power steering leak on a 1989 oldsmobile delta 88 royale 3800 engine the power steering pump is good and less than a year old the fluid is leaking sumwhere underneath the car on the driver side of the...
Pretty old car there, Reginald, (that from a guy who drives a '79 Datsun!)
You'll have to get under there for a close inspection. Raise the car up on jack stands or blocks. Hopefully, a hose fitting may have loosened where it connects to the rack and pinion gear, and only needs tightening. Or a hose may have ruptured and will need replacing. There are two hoses from the pump to the rack, a supply line and a return line. If you see fluid on one, bend it back and forth to look for a break or leak.
The worst case would be a PS fluid seal failure inside the rack and pinion, requiring a new or rebuilt unit. Just paid $240 for a rebuilt unit for a Chrysler last year, to give you an idea.
If the fluid drips from where the rack and pinion steering gear is mounted on a crossmember right behind the engine, peel back the rubber boots on both ends of the rack gear (where your tie rods enter the rack and pinion) and check for fluid there. If a lot of fluid, the seals are bad. In that case, consider a used unit, or a rebuilt, or get used to no power steering. Good luck.
Jan 09, 2013 | Cars & Trucks
When does rack go bad my van is 4 and half years old less than 28,000 miles
Steering Rack? Have to change /flush oil every few years. Should last ten or more years but some don't. Flush system and install an inline filter on return line, before you install rebuilt rack. Instructions to same, come in box.
Mar 11, 2010 | 2005 Dodge Caravan
Need a drawing of the worm shaft and spool valve assy.
closest I have is 94 explorer. may be similar.
Item Part Number Description 1 3E501 Steering Gear Sector Shaft Seal 2 3524 Steering Gear Input Worm Gear and Rack 3 3647 Steering Gear Worm Ball 4 3523 Steering Gear Ball Return Guide 5 3A670 Steering Gear Worm Thrust Bearing Adjuster 6 — Locknut (Part of 3577) 7 3571 Steering Gear Worm Thrust Bearing 8 3575 Steering Gear Sector Shaft 9 3524 Steering Gear Input Worm Gear and Rack
May 09, 2009 | 1983 Ford F 250
T5 vw transporter shuttle gears wont engage to drive vehicle
try checking your gear linkages make sure it is actually engaging in the box before you go any further
May 28, 2008 | 2005 Volkswagen Microbus
Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Feb 24, 2007 | Xerox Phaser 6250DP Laser Printer
Cycling Logo
301 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
