Question about Dell OptiPlex GX280 PC Desktop
My motherboard won't start with power button waht can i do ?
  • 903 Answers
The three most likely culprits are the power supply, the motherboard itself, or the power switch. Chances are good that the power supply went bad, so if you just want to try replacing something, start there.
If you have a multimeter and you're comfortable using it, remove your computer's case so you have access to the motherboard and turn the PC on, then meter the connections coming out of the power supply. If they all look good (giving out 12 volts, 5 volts, and possibly 3.3 volts or less depending on your motherboard) check the connectors coming off of the motherboard. If those connectors are transmitting the voltage, then check your power switch to see if it changes state when you press it.
One of those three components will almost certainly be your problem. If you don't have a multimeter, your best bet is to start with the power supply. Other than a floppy disk drive, that's usually considered the most likely component in a PC to fail.
If this article has helped you, please consider rating it. Thanks!
Posted on Sep 30, 2010
Waht is calibration
firstly power off
then
while feed button press, power on
wait printing test page then release feed button
wait stop printing then power off .
now start nor mal power on
calibration now finish
Jun 11, 2014 | Argox OS-204 Thermal Label Printer
Waht is calibration key
Firstly power off
then
Won't Boot after pressing the power buttton
Unplug the tower and press power button for 60 seconds, if this fails the motherboard should be suspect, check all plugin connections to the motherboard especially power supply connectors.
Jun 17, 2012 | Dell XPS 8300 Desktop
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
Hp touchsmart 310 pc power flashes 3 times and won't start
people,people please I know I saw it too late but this is the solution
replaced the Power board button with the cable that goes from the power button board to the motherboard.
part # 625223-001 (hp touchsmart 310 swith board(Shasta)
thank you.
Feb 10, 2012 | Computers & Internet
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | Computers & Internet
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
Pc won't start on 648fx-a2
Please provide further details. What happens when you press the power button? It does not automatically mean that your motherboard is failing.
Jul 29, 2011 | EliteGroup 648FX-A2 Motherboard
I have done it before but have forgotten waht 'F' keys I have to press duriing start-up to format mt e system 3083 laptop - can you help?
While the pc is off turn it on by pressing the power button, immediately after you press the power button start tapping the F10 button and keep tapping until the recovery menu appears.
Regards.
Sep 15, 2009 | Computers & Internet
Dell OptiPlex GX280 PC Desktop Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
