Question about Bernina Activa 130
Needle always stops in up position
Is there any setting on the Bernina Activa 130 to make the needle stop in the down position (still engaging the material)?
I have the Activa 131 and while the needle is made to stop in the up position, all you have to do is push the bottom of the peddle quickly with your heel and the needle goes into the material and stays until you start sewing again. Hope this is helpful.
Posted on May 27, 2008
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
My bernina activa 130 is suddenly making very fine, tight stitches. How do I solve that?
Remove the needle plate (by pushing on right rear corner of plate) and clean out any lint build up from the feed dogs and replace plate.
Sep 22, 2016 | Bernina Activa 130
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Free print manual
there are Bernina manuals as pdf's on their website, www.bernina.com, then go to Support, choose your manual in the drop down box and download it. There is not one there for the Activa 130 but the 135 is there and the 125, both will be very close to your mode.
link is http://www.bernina.com/en-AU/Support/Machines/BERNINA-activa-135
Oct 13, 2012 | Bernina Activa 130
My bernina activa 130 wont sew
Fit a new needle, clean and oil the hook race, whether-or-not your manual says it doesn't need it and check that you have some tension on the thread coming out of the bobbin case and top tension unit. Are you threading the top thread with the foot up or down ? You should always thread the machine with the foot up to ensure the thread goes through the tension unit properly.
Mar 02, 2012 | Bernina Activa 140
On other Berninas you are able to take one stitch and end the stitch with the needle in the down position. I can't seem to find a lever, button or anything to allow me to do that on my Bernina Activa...
If you don't see a button that you can select for needle up / down, then you can't. Your foot control might might have a symbol at the lower side that shows and up / down arrow. If so you can tap the bottom edge of the foot control and the machine will half cycle, stopping with the needle in the down position.
May 12, 2011 | Bernina Activa 140
How do you oil a Bernina Activa 130? The manual doesn't say anything about it.
Remove needle, needleplate, presser foot and bobbin case. Now take a lint brush and clean under the feed dogs and hook area. take the bernina oiler(must be bernina oil only) now place a drop just below where the bobbin case clip on and one small drop under the feed dog area. replace items, sew out a test sample and away you go.
Apr 27, 2010 | Bernina Activa 130
Sewing Machines Logo
263 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
