Question about Garden
How do you lay lock block paving - Garden
I am laying a walkway with paving stones. If I add 2 inch of sand to 375 sq feet of space, how much cubic ft of sand will I require?
Since a cubic foot is 12" x 12" x 12", if you were to make the sand 12" thick you would have 375 cubic feet of sand. However, since you want your sand 2" thick (which is 1/6th of a foot), you simply divide the 375 by 6 to get the value of sand in cubic feet (62.5).
Nov 17, 2016 | Office Equipment & Supplies
What is the lever on the transmission of the Buck 500 4/wheeler fot
It locks up the differential. Positraction. Leave it OFF if using on paved surfaces. Leaving it locked will increase tire wear on hard surfaces. Use only on areas where more traction would be required.
Mar 01, 2015 | John Deere 2006 Buck 500
How to lay patio block?
Rather than going through the entire process of laying patio block, I suggest you do a web search just as you are asking; "how to lay patio block?". There are numerous videos on this subject, as well instructional sites.
Jun 04, 2014 | Building Materials
I am trying to clean my block paving using my pressure washer Karcher 3.99, which I used successfully last summer, however, it is not cleaning well. I have used the high power nozzle but the power seems...
Hello Sue, you don't say where in the world you live, but if you are attempting to clean dirt and algae off pavers, you need to add a solution to the water jet via the inbuilt attachment. Mix a fairly mild solution of bleach and detergent, pus a dash or deodoriser to the cantainer. Put your karcher on low pressure and give all the blocks a good wetting. Do this in the morning so the solution doesn't dry. After 20 ~30 mins, Claen off with the Karcher on normal high pressure (not the tubo lance). HINT: Leave the trigger on all the time and don't stop and start using it. This will prevent hayraulic hammer which can split the pump head.
Apr 11, 2010 | Karcher Garden
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
