Question about Acer Aspire 3680 Laptop
Windows failed to start - Acer Aspire 3680 Laptop
    President:
  • 2,291 Answers
Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with Reg In Out Registry Cleaner and PC Optimizer
Posted on Oct 04, 2010
Windows boot manager says windows failed to start, why?
This is caused by a corrupted boot file, maybe it has been turned off or had a power failure when shutting down.
Aug 19, 2015 | Acer Aspire 7540 7736 Intel Laptop...
Windows fails to start
Is the hard disk, change the hard disk and/or the sata interface wire.
Mar 10, 2012 | Toshiba Computers & Internet
Windows fails to start on my e-machine w3623 with windows vista
where does the comnputer fail to load at. If you have installed windows again and the computer fails to start it is a hard drive or cable problem. Does the computer give you a error message (like 1XX,2XX,3XX Etc.
Sep 27, 2010 | eMachines W3623 PC Desktop
Will not boot
If you dont have the option to run:
"Windows XP Recovery Console"
You probably have to install windows on a second PHYSICAL drive, Disconnect the failing one first!
Reconnect the failing drive in slave mode.
1. Start/Run "cmd.exe"
2. execute "chkdsk /F /R /X D:"
3. Shutdown
4. Swap drives.
5. Start system (while praying :) )
Jul 18, 2010 | Microsoft Windows XP Home Edition
You need to re-install windows mate.
May 20, 2010 | Toshiba Satellite A305-S6852 Notebook
Fails to start
Insert the installation disc and select repair.
If problem persists, format the windows partition and install a fresh copy of the OS from a ORIGINAL CD.
Mar 26, 2010 | Microsoft Windows 98 Second Edition for PC
Power windows don't work
This could be several things: lets start with the basics, check for a blown fuse or failed wire (this would especially hold true if they failed at the same time. Could also be control switch (does the passenger switch operate its window?) if this is the case the master switch has either failed or failed wiring. Lastly there are the window motors, these too may have failed. If it sounds as if the windows are trying to operate but unable to move; the mechanics of the windows may be coroded, overly dirty or in need of lubrication (WD40)
I hope this may have helped,
Tom
Sep 23, 2009 | 1992 Dodge Dakota
Try safe mode if you can. if you cannot and it is windows xp repair install. if vista tell it to do fix it via the vista disk.
Apr 29, 2009 | Computers & Internet
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
