Question about Canon PIXMA MP830 All-In-One InkJet Printer
My screen on my printer says error 6A00 error code. I have turned printer on and off...not sure what is going on
  • Canon Master
  • 12,061 Answers
Http://www.fixyourownprinter.com/forums/inkjet/39177
See website above for all details to do with this error.
Unfortunately 6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You most likely will NOT be able to resolve the problem yourself, sorry.
Your service and repair manual is below, for you to download. All error codes and fixes are in there.
www.pdfoo.com/result-pixma-mp830-service-manual-.html
Posted on Sep 30, 2010
Error code 6A00 when you turn printer on
AP position error causes the 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board assy (QM2-3078), Purge unit (QM2-2925).
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00
>shutdown the machine & disconnect it from the computer
>check for any obstructions
>power on and try re-seating the cartridges
what happened before this issue started ?
Aug 25, 2008 | Canon Pixma iP6600D InkJet Photo Printer
There was a paper jam. I got the paper out but now error message 6A00 appears in the screen. I have tried to turn off and on.
The error code means paper path jam.
Inside your printer a paper path sensor has been activated indicating paper jam so the printer will give off a 6A00 code.
So please check for any stuck paper, debris
The offending item needs to be removed or the purge unit needs replacement.
Also clean the purge unit out make sure all is clean
May 11, 2010 | Canon PIXMA MP610 InkJet Printer
Canon pixma all in one mp500 error code 6A00
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Sep 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Error Code 6A00 is a problem with the sheet feed unit. You cannot fix it by yourself because you do not have the tools to fix the printer.
You go to a Canons Support Page and ask for a replacement if it is still under warranty or you replace the printer with a new one.
Aug 16, 2008 | Canon MP830 All-In-One Printer
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
212 people viewed this question
old marine
old marine
