Question about LG Art Cool LA1000PR Air Conditioner
Lg neo plasma ac displays code C1 . resistence across evaporator air thermistor is 7k ohm @ 28 celsius
hvac1960
  • 2133 Answers
SOURCE: i have a "cl"or "c1"
C 1 means indoor thermostat sensor defective.
Posted on Dec 13, 2010
22yooper
  • 828 Answers
SOURCE: cutting of thermistor wire by rat
If you have enough loose end on the wire you can make a splice and solder the point. Insulated it well with electrical tape. The alternate is to replace the thermistor which and more than likely be ordered by model number and serial number of your unit.
Posted on May 28, 2008
  • 334 Answers
SOURCE: need to find manual to download for LG 2.5 hp neo
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Posted on Jun 11, 2009
  • 400 Answers
SOURCE: I have one code in the LG air condition and the
This indicates that the return air sensor is either not connected correctly, or is in the wrong position and not clipped in (in front of fins) This sensor can be seen if you lift the front cover, remove the filters, it is clipped to a plastic fitting on the fins. It is also very likely that it is faulty and needs replacing.
Posted on Nov 04, 2009
hvac1960
  • 2133 Answers
SOURCE: LG neo plasma air conditioner
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Posted on Jan 04, 2011
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Midea floor standing air conditioner displaying error code E6.Please what does it mean and possible solutions.
Google says:
E6 Room temperature or evaporator temperature sensor open or short circuit
The prescribed cure:
Check to make sure the room temperature sensor is connected and reads the correct resistance value. If the sensor operates correctly, replace the control board.
This unit most likely employs a NTC thermistor as a thermometer sensor. Common resistance values are 1k ohms and 10k ohms at room temperature. As the temperature goes up, the sensor decreases in resistance.
The sensing element could look like any of the above, but with portable comfort units, they usually look like the bottom row of encapsulated and cabled assemblies.
Feb 09, 2015 | Midea Heating & Cooling
Error code E01 on my electronic dryer
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks!.
May 27, 2011 | GE DCVH515EFWW Electric Dryer
I have a lg neo plasma inverter ( s24awn-4) it turns off and comes up with a fault code (26ch) can any 1 help?
Inverter compressor seized. Check compressor windings all equal resistance 1 to 4 Ohms, check to earth 50 MOhm minimum, check run current and Inverter outputs. Helpful?
Dec 26, 2010 | Heating & Cooling
I have a "cl"or "c1"
Dec 11, 2010 | LG LA185HV Split System Air Conditioner
How do I take the front panel off my kenmore elite electric dryer to see if their are tech notes about my E1error code? My dryer turns off after only a few minutes displaying and E1 error code. The...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Kenmore Elite HE4 Electric Dryer
We have an he3 dryer, it keeps stopping mid cycle and the display reads E1
Hi
E1 error means its a Thermistor Failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Kenmore Dryers
What is error code e1?
May 11, 2009 | Kenmore 73952 Gas Dryer
Error codes
Jul 25, 2008 | Kenmore Elite HE4 Electric Dryer
Evaporator unit turns on for about 15 seconds then turns off
Out of range thermistor can cause the tripping of indoor or outdoor unit. Try to check the resistance of your thermistor it should be 8 to 10 kilo ohms at 25 deg. c temp.
Oct 31, 2007 | LG LSC121PMA Split System Air Conditioner
LG Art Cool LA1000PR Air Conditioner Logo
320 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
