Question about Electrolux Lux 5500 Canister Vacuum
Electrolux 5000 light is on where it normally says chande out bag. vacuum still will not run with hose on. with hose off works fine.
  • 328 Answers
Clear solution here - the hose is blocked.
Using a blunt stick with blunt ends, remove the entire hose assembly and compact up with the stick. Wriggle the stick a couple of times and this should dislodge whatever has got stuck up the hose.
Dont forget to rate, thanks,
Posted on May 25, 2008
Check bag light on and bag fine. also seems like it is shooting stuff out of vent on top
Hi!, It's Jim with Crucial Vacuum,
Often times when your vacuums bag light remains on even after installing a new bag there is an air flow problem within your vacuum, or clog. This would explain why there is debris shooting out of your vacuums top vent.
Remove your vacuums bag and check to see if there are any clogs where the bag would attach normally. Clear out any noticeable debris.
While you're looking for clogs, check your vacuums hose, brush roll and filters. Stretch your vacuums hose out completely to unearth any debris. Manually spin your brush roll to help release any clogs, and wash your filters, but be sure to allow them to fully dry before re-installing them.
This should undo any clogs in your vacuum and cause your bag light to turn off.
You can purchase replacement parts for your Hoover vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Hoover&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
http://www.CrucialVacuum.com
Jan 14, 2015 | Hoover U6437-900 / U6439-900 Windtunnel...
I have an older model Electrolux canister vacuum and it turns off quickly after turning on and this checkered light comes on. It happened right after i finished cleaning the ashes in my stove which i...
Make sure there is no obstruction anywhere along the hose. Also properly clean the filter and collection bag. This may have become blocked due to the fine ash, sort of sealing the bag.
Jan 02, 2018 | Electrolux Guardian Bagged Canister Vacuum
While vacuuming the red light for the bag of the vacuum came on and the vacuum stopped. The bag was no where near full so I replaced it with a new bag - same problem. It vaccumes for a minute or then stops...
I'm assuming this is the Epic 6500 or similar model.
Detach the hose, turn vacuum on. If it runs, place palm of hand against inport hole. If it shuts off the problem is with either the control valve setting or the control valve assembly itself.
For cvs, turn dial on top of vacuum all the way to the largest dot, and try above test again. If that doesn't work, then it's the CVA. It needs to be cleaned or replaced, which is an in shop job. Fro repair, take it to the nearest Aerus Electrolux store. I recommend a full clean and service to remove any dust/dirt from the motor, fan assembly, and other internal parts.
Another problem, which relates to the dial setting, is that fine dust will quickly clog the pores of the bag, resulting in the machine "thinking" the bag is full. Turning the dial to the proper setting helps get the bag fuller. The middle setting is the normal setting, and is for areas without fine dust and sand.
Dec 05, 2010 | Electrolux Vacuums
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuum shuts off, bag light on, runs fine without hose connected
I'm not sure if I understand your problem completely, but if it is your full bag indicator that is coming on, even with a new bag, it's probably your control valve. These can be replaced by your dealer. When working correctly, the control valve should trigger the off switch when the differential pressure gets too great between the front of the bag housing and the area behind the bag. When it goes bad, it will indicate that you need to change your bag, even when you don't. Good Luck!!
Oct 30, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux 2100 canister vacuum
check the hose by putting a penny in one end and see if it comes out the other, you might have a possible clog, lux canisters are designed with a fail safe
Jan 19, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Lux 5500 Canister Vacuum Logo
123 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
