Question about Nokia 6300 Cellular Phone
6300 only blue led only ist boot ok and error ....
6300 1st boot error
vinay mobile
Posted on Feb 02, 2011
I have an acer aspire ax3960. The problem I have is that it will not boot up, here is a list of the current process that happens; 1. I press the power button, and for a millisecond the blue LED on the...
Try removing the battery, power supply, hard drive and RAM. Power up and see what happens, you Acer should complain. If it does, the mother board is probably OK. remove the power, fit the RAM and try again. If it now tells you it cannot boot, suspect the hard drive but power down, fit the drive and check it.
May 03, 2014 | Computers & Internet
My humax will not come blue led flashing
This is an indication of some error inside. Since loose contacts in power outlet, RC jack, cable and connectors can also trigger this mode, make sure these are ok. Then, call in a qualified service technician if it is necessary to open the back cover for investigation/rectification.
Aug 22, 2012 | Televison & Video
6300 error code
Alarm LED lit
RAM error [6300] The RAM error occurred in the RAM check at hard-power-on.
Its a hardware error. In most case the logic board assembly is failed or an internal error of one of the ASIC chips on the logic board and can be repaired by replacing the logic board at the Canon Service Center.
Feb 18, 2011 | Canon PIXMA MP830 All-In-One InkJet...
PHONE WON'T TURN OFF
For Nokia 6300
  1. Remove the battery to turn it off then insert it again.
  2. Press the power button. The blue LEDs on the sides should flash and the phone turns on.
  3. If the blue LEDs do not flash, you have a broken power switch.
  4. If the blue LEDs flash but the phone does not turn on, you have a weak battery or hardware/software problem.
  5. If the battery is good, have your phone checked by a qualified technician.
Nov 29, 2009 | Nokia 6300 Cellular Phone
NEVER POWER UP
the problem might be with your display or the display pin not with your board
Sep 24, 2009 | Nokia 6300 Cellular Phone
My samsung NW920 turns off after 1 min
If the blue LED ist blinking the monitor does not receive a video/sync signal. If the blue LED is on continuously and the display comes on for a few seconds and then goes dark or dim the backlight inverter may well be defective. The CCFL of the backlight needs several hundred volts to function.
Jan 11, 2009 | Samsung SyncMaster 920NW Monitor
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Water damaged, No Power
ur handset 3 time washin in washin machin with ariel.
Aug 30, 2008 | Nokia 6300 Cellular Phone
DOWNLOADING MUSIC VIA BLUETOOTH DONGLE
might be what ur downloading needs more space then ur memory card got. ist it?
May 24, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
358 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
