Question about LG Kitchen Ranges
My Lg washing machine is not intaking water supply
  • LG Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 30, 2010
What is error IE in LG FR1352NCZ washing machine? TIA
This IE error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Apr 24, 2017 | LG Washing Machines
Intake Cold water filling into machine while turned off
You have either a faulty solenoid valve on the cold intake or you may have knocked some limescale into the valve while changing the pipes. Try some descaler in the valve first and operate a few times. Hope that makes sense!
Feb 01, 2016 | Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
No water is getting into the washing machine. Error code display and soap is still in dispenser.
machines have a hot water and a cold water intake
if the water cold isnt getting to the blue intake it wont work
as you have an error code
post the error code it displays
you posted insufficient info to come to a good recon
Sep 24, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer
HOW to fix E1 code for LG direct drive washing machine
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
Aug 25, 2014 | LG Washing Machines
What is E1 codes for LG washing machine
Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on.
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Saying water supply not adequate
is your house water presser gone down Re: Jeff
Apr 12, 2012 | LG Washing Machines
Getting f 20 error
F-20 error code for the Whirlpool washing machine is indication of inadequate water supply.
Check both hot and cold water supply lines to make sure machine gets enough water intake.
Also check the filter in the hoses for blockage
Nov 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Feb 18, 2008 | LG WM2688H Front Load Washer
Kitchen Ranges Logo
252 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
