Question about Koss KS2503 System
DVD Tray stock closed Koss ks 2503
Hello we have a Koss ks 2503 and the dvd tray is stuck closed. We get mess 04 on the display.
please help.
thanks you
See if you can acquire the software upgrade that Koss engineers devised to solve the problem, I did have one(the upgrade) but misplaced the disc, if you manage to obtain it please e-mail me.
Art.
Posted on Jun 08, 2008
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Disk stuck in Koss c928. DVD powers up and says waiting. How do I get the disk out and how do I reset unit
There should be a small hole on the door of the disk tray. insert a paper clip in the hole to manually open the disk tray. remove the disk and see if the tray will open and close normally. If it does put another disk in and see if all is well. If not I would have a repair center look at it.
Jan 31, 2010 | Koss C928 System
I am getting the locked display
Hi Blackhawk,
This sounds like you've accidentally set the "tray lock" feature.
You can set this to stop unwanted tray ejections:
I hope this solves your problem..
Warm Regards
Mike
Nov 28, 2009 | JVC TH-M303 System
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
I,ve touch a function and my dvd plays but it is Black and White and the image rotate, I know that I went into picture ...i believe and set it to something else cannot bring it back to normal function DVD...
yes , i can help,> open dvd tray, your player will go to menu but it will be jumping so look to bottom of screen to tell what function you are in. scroll down till you see "display lets you display picture etc." when you see this at bottom of screen hit enter and and hit bottom arrow you will see pal/ntsc option hit enter again and your picture will return to normal good luck.
Nov 26, 2008 | Koss KS3112 DVD Player
Dvd tray will not open
replace the player. The feeding mechanism is not working.
May 01, 2008 | Koss KS4110 DVD Player
Koss KS2503 "MSG 04" problem
I had this MSG 04 problem. Opened the player up. Messed around. Figured out that the 5-disc tray was hanging up a little during the initialization. The issue is that the tray screws into and rotates around a stand-up beam. On the underside of the tray are gear teeth which are spun by a gear on the main unit underneath. The real culprit is the stand-up beam in the very middle. It is too long. The fix is to first try just tightening the middle black screw holding the tray onto the stand-up beam. If this tightens and MSG 04 goes away, you're done. If it does not tighten at all or much at all, then remove the screw (actually a bolt) and using a razor or sharp blade, scrape the top 1/4 millimeter off the stand-up beam. Apply some grease around the beam and on top. Note, you may have to remove the tray to do all this. If so, that is the most tricky part. Carefully lift on the tray on the front side as you rotate it. Try to free a disc circle edge over the top of the front DVD cover and free the tray. To re-set the tray, put it on the stand up beam with the front side of the tray slanted up and slowly rotate while setting it in and down. After re-seating the tray, screw the bolt down but do not tighten all the way. Tighten it enough to allow rotation and enough to rid the msg 04 problem. I shaved my stand-up beam and have never seen a MSG 04 since.
Apr 01, 2006 | Koss KS2503 System
Koss KS2503 System Logo
108 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steve K
Carlos L. Burgos
Carlos L. Burgos
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
