Question about Health & Beauty
Need the encryption codes for Siemens ACUSON 128 XP/10 Ultrasound Machine. Please let us know if any help can be rendered. Regards Rajeev VErma
  • 903 Answers
SOURCE: 128-bit encryption
Yes, Pocket IE supports 128-bit encryption.
Posted on Sep 15, 2005
  • 10 Answers
SOURCE: IE 7.0 Change it into High Encryption.
u can change the cipher strength by edit the properites of the IE7.0
or change in "services" which is in control panel -> Administrative Tools
Posted on Mar 15, 2008
Bappa170873
  • 505 Answers
SOURCE: The case on my day
You can call this no. 1-866-306-8239. If the case is broken you can get it repaied but as you said it is 10 yrs old you may end up paying more.
Thanks
Posted on Oct 31, 2008
  • 52 Answers
SOURCE: apple i touch
Do a seach on google for your router instruction manual or alternatively try and find the paper manual that came with it.
All routers have an IP address which you type into your web browser. For example, rather than typing www.google.com, you might type http://192.168.0.1 to access your router. This special address is known as the gateway address.
From here, you are normally requested to enter a username and password, which are usually the same for every type of router. (The manual will show these, look for "default password/username".
Once you've successfully logged into your router you can change numerous settings including your wireless security. Again, look for wireless/security settings in the router user manual
Posted on Jul 02, 2009
  • 65 Answers
SOURCE: DS6608 scans encrypted barcode triggers print
You need to program the scanner through 123 sofware or by scanning specific barcodes. I can provide you with either or need. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Posted on Oct 21, 2009
Tip
How to setup WEP on an SMCD3GN Wireless Cable Modem Gateway 1. Log into the...
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.0.1
2. You will need to log in to the router. The Default Username and Password:
User Login
Username: cusadmin.
Password: password
3. Next click on [WIRELESS] link on the Side Navigation bar.
4. Select [WEP] from the [SecurityMode] drop-down menu.
You can choose between standard 64-bit or 12b-bit encryption keys. Below are the configuration options for 64-bit WEP. A passphrase or a manual key can be used
NOTE: To enter a manual WEP key you will need to enter hexadecimal values (A-F and 0-9). Example: 64-bit hexadecimal keys are exactly 10 characters in length. (123654ACDE is a valid strong of 10 characters for 64-bit encryption).
To automatically generate a 64-bit WEP key, enter in a Passphrase (keyword- ex. homegateway). And click the [Generate Keys] option. Once you do this, the Gateway will dynamically generate 4 keys. Simply configure the Default Key to the one key that you will be using across your network.
5. Select the Open System, Shared Key or Automatic from the [Authentication] drop-down menu. Note in most cases you want it set to Automatic.
For more security, you can use 128-bit WEP encryption. To use this mode, select the [128 bit (26 hex digits)] from theWEP Key Length drop-down menu option and the configuration section will be displayed. 128-bit encryption requires a longer key than 64-bit encryption. Keys are defined by entering in a strong in HEX (hexadecimal- using characters 0-9, A-F) or ASCII (American Standard Code for Information Interchange – alphanumeric characters) format. ASCII format is provided so you can enter a string that is easier to remember. The ASCII string is converted to HEX for use over the network. You can manually enter in the 26-digit hexadecimal key.
Example: 128-bit hexadecimal keys are exactly 26 characters in length. ( 234FEDCBA12340013333389319 is a valid string of 26 characters for 128-bit encryption).
NOTE: If you are having a difficult time getting the wireless connection up after enabling WEP- Please confirm that you have configured the SAME WEP key on both the Gateway and Client card.
6. Click the [Apply] button to save your settings
on Feb 26, 2010 | Computers & Internet
Acuson antares user manual
Could you please say what OS do you have and what browser are you using?
Mar 05, 2013 | Computers & Internet
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
I changed from 64 bit to 128 bit back to 64 bit in 1 hr. It was an accident, and now my laptops will not recognize my router. My cable company has tried everything over the phone.We have changed the...
When you changed the WEP encryption from 64 bit to a stronger 128 bit encryption the encryption code gets changed and when you changes it back to 64 bit the new 64 bit encryption code will be different to the old 64 bit encryption code, that is why your laptops cannot connect to the router. The laptop wireless card needs to be configured with the new 64 bit encryption code before it can connect to the wireless router.
I suggest you configure the wireless router with WPA or WPA2 encryption, this is a much stronger encryption method than the old WEP encryption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 12, 2010 | Computers & Internet
I am doctor who specializes in ultrasound. My problem is that the current DVD recording system we are useing to record our ultrasound studies have imperfect resolution. Can you recommend one that will...
I am sorry to ask you another question, but in order to give you the appropriate answer, I have to know your exact needs.
You want to record the images and cine loops and currently use a video/frame grabber to capture these signals into a computer.
If you are a specialized Ultrasound doctor, why don't you use the DICOM standard for storage and archiving? There are great free software packages out there you can use for this! It will give you the best medical solution for this purpose and if you need after exam measurements etc, all the image display information (pixel info etc.) is already available in the DICOM information. Any DVD recording will give you a limitation in these functionalities.
If you want to proceed with DVD recordings, please be aware that the average Ultrasound pixel resolution is 512 x 512. Besides this, Ultrasound is always noisy and kind of "blocky"..The DVD will never increase this quality and can only downgrade it if incorrectly setup.
If you need more help or information about DICOM use, please let me know and no, I will be obliged to provide you with more information about this great standard.
Nov 07, 2009 | Philips TV Tuner Video Capture PCI Card -...
How do I Enable Encryption or secure my wireless Network?
To enable encryption, you need to log into the router's configuration page: Click on Login -> Advanced Setup -> Wireless -> Encryption Think up a Hexadecimal code with the appropriate amount of characters for the level of encryption you wish to use (Hexadecimal means you can use any number between 0 and 9, and the letters A through F). 128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9 64-bit encryption uses 10 characters. Example: 01 A3 45 F7 89
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Health & Beauty Logo
172 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
