Question about Garden
Honda 2216 lawnmower cutting deck - Garden
3 Suggested Answers
  • 135 Answers
SOURCE: i have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Posted on Aug 02, 2009
heatman101
  • 43501 Answers
SOURCE: my craftsman riding lawnmower 42"
The first thing to check is the wheels on the back corners of the deck....amke sure that they are set at the same height and that the bearings are not out of the wheel, which would allow the deck to sink lower on one side.
If all of that checks out then you have problems under the deck....
The bearings that hold the blades can wear allowing one of the blades to drop, or one of the blades could be bent which could cause it to cut lower...to fix that bearings will have to be replaced or the blades will have to be replaced if bent.....
These would be the causes for your mower to cut unevenly...
heatman101
Posted on Apr 09, 2011
My riding lawnmower not cutting even, craftsman 46"
first check that the blade or mandrel is not bent or damaged --and check the air pressure in tires on right side --lower deck towards ground on a level surface until left makes contact now adjust the level arms they are on either side of cutter till right side is level with left on some of the older decks can adjust the front deck wheels also
Aug 25, 2016 | Craftsman Garden
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
HONDA 3011 LAWNMOWER RIDING HOW DOES THE BELT ON MOWER DECK GO ON? DIAGRAM
I dont have the diagram but remember the V of the belt aways goes in V pulleys and the back of the belt on flat pulleys . Honda provides you with diagrams at hondapowereqipment .com
Sep 28, 2009 | Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a husqvarna 172 ride-on lawnmower. Running
Aug 02, 2009 | Garden
Lawnmower cuts out on fast idle + runs rough
REBUIld carb it is dirty jet is clogged
May 25, 2009 | Echo Garden
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
