Question about Acer Aspire 3690-2196 Notebook
Well I have Acer Travelmate 4335 laptop & it was working well but suddenly at one morning I have turned on the laptop & whole screen appears as white and still it is in d same position. I have not connected my Laptop to external Monitor? What will be d problem? Plz help me out.
IB4G2008
  • 3587 Answers
SOURCE: Pink/Green Background Acer Travelmate 2410
you are having an lcd experience of the 3rd kind..i'd venture to say your in for a replacement event.
Posted on Feb 27, 2008
imp_squared
  • 56 Answers
SOURCE: Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Posted on Oct 01, 2008
SOURCE: white screen problem in acer aspire 4710
You will have to disconnect and reconnect the video signal plug located under the upper cover (the one with the power button on it). Best you start with a screwdriver in the very corner).
See also: http://blog.shimpossible.com/2007/07/18/white-screen-of-death/
Additionally I removed a small magnet located under the lid cover (remove 6 screws under rubber placers and lift the lid), which I found next to the video cabling. This could have affected the video signal negatively. Lets see how long this fix lasts.....
Posted on Dec 26, 2008
  • 6 Answers
SOURCE: Connecting an external monitor to acer 5720
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
-David-
Posted on Jan 09, 2009
  • 489 Answers
SOURCE: i have a acer travelmate 3270.
you can download from http://support.acer-euro.com/drivers/notebook/tm_3270.html
choose operatiion system, download and install.
Posted on May 31, 2009
My drivers for acer travelmart 4335 corrupted, want new drivers
You can get the drivers from here: http://support.acer.com/product/default.aspx?modelId=787
Those are the copy of all the drivers that are included inthe disc.
You can download them and install them in your computer or you can save them in a hard drive or usb drive for future use.
If you don't want to update your drivers manually, I suggest that you install RadarSync to your computer. What it does is it automatically updates your driver. You won't have to do anything at all. It is like a computer technician inside your computer.
Nov 25, 2012 | Acer TravelMate 4335 Drivers Recovery...
Acer 4320 can not switch on properly. after a few minutes turn on, suddenly black out.
The problem is most likely the DC jack in the laptop, causes are no power to intermittent operation, but if the screen blacks out it means the LCD display has issues especially if the rest of the laptop is working, could be a loose video cord from the screen to the motherboard has come loose.
Jun 10, 2012 | Acer TravelMate 4320 Notebook
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
Acer travelmate 4050 bios setup password, reset password is required
hello, and I have a problem with Acer TravelMate 4050 and the problem lies in the total extinction of the system, namely when you turn on Windows light up when you enter and suddenly black screen and do not even think about blocking it immediately, but he remains on but do not think .... that is the problem?waiting for a response or contact id doi_ochii multtumesc advance ....
Oct 05, 2010 | Acer Computers & Internet
My Travelmate 290 series is not working...
Try taking the memory out and then put it back in making sure it seated correctly then start using AC power lead it's probably caused by letting the battery get too low before recharging.Use a start up disc to get it going if you have to. Good luck
Aug 02, 2009 | Acer TravelMate 290 Notebook
Need help using Recovery CDs on TravelMate 290
run the command rstrui.exe to restore the system if it does not work only way is to reinstall os
May 08, 2009 | Acer TravelMate 290 Notebook
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Black screen
Sounds like the inverter that poweres the backlight is dead. Search on eBay for the FL inverter for your model. Should be easy to replace.
Jul 04, 2008 | Acer TravelMate 2500 Notebook
Suddenly a black screen!
If your good with computer or know some one that is, sugggest you to remove the LCD rim, and clean the ribbon filament that is connected to the monitor. Sometimes this filament get's dirty and just need to be clean from a cotton swab.
Another solution is for you to plug in a monitor to the laptop.
May 06, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 4500 screen problem
if u have two memmory stick.try to boot with one..if it not ok try it with other one...
Nov 30, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 3690-2196 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
