Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
When I push the start button of the PC, the fan of the processor of the motherboard ECS 945GCT start running and nothing appear on the screen. It seems that it hangs somewhere on the POST. Is there a solution for that problem? Thanks
  • EliteGroup Master
  • 27,725 Answers
One bad/faulty lead can cause a computer lots of problems
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty
hope this helps
Posted on Sep 30, 2010
Problem upgrading CPU
Try to update the BIOS with the old CPU in, if not the new CPU could be faulty, yes I know it's new but it is entirely possible
Apr 19, 2014 | eMachines W3619 PC Desktop
PC not booting up.
if its windows after you push the power button keep pushing f8 till you see a boot menu / choose boot in safe mode then you can use system restore /sounds like a bad driver/ loose processor/bad fan improper cooling could be the graphics card itself
Aug 02, 2017 | ASUS P5N73-AM Motherboard
Ecs motherboard 945GCT-M/1333 no video display after post beep
ECS motherboards are 'Budget' motherboards.
In other words they use low quality components on the motherboard.
1) Did you FOLLOW Anti-Static Precautions?
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out, (Short Circuit), the delicate hardware components in a computer.
Relieve your body of Static BEFORE working on a computer.
Computer on a table, computer Unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
[ A bed, couch, or directly on a carpet floor, are HIGH areas of Static ]
[ FYI: A Processor is the MOST susceptible hardware component to Static shock.
Also you probably won't see it, or feel it. { Static ]
If you did not follow Anti-Static Precautions, more than likely your motherboard, processor, and even the graphics card/s, are now expensive paper weights, or doorstops.
2) The ECS 945AGCT-M/1333 motherboard, has an LGA 775 processor socket,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=830&CategoryID=1&MenuID=16&LanID=0
(Click on - More pictures, for a clearer view )
Intel Core2 Duo processors run pretty hot,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Dual-Core_Desktop_processors
(Also scroll down)
Take the Intel Core2 Duo E4500, for an example,
http://ark.intel.com/products/30781/Intel-Core2-Duo-Processor-E4500-%282M-Cache-2_20-GHz-800-MHz-FSB%29?wapkw=e4500+tdp
The case thermal limit is 73.3 degrees Celcuis, or also stated as 163.94 degrees Fahrenheit.
This means that the Thermal Paste can dry up easily over time.
To digress;
The top of a processor's case, and the bottom of the finned Heatsink, that sits on it, is not perfectly smooth.
A magnified view would detail, 'Pitholes, Valleys, and Hills'.
When the two parts are mated together, (Processor and Heatsink), it creates air pockets.
Air is an Insulator. Not a Conductor.
Thermal Paste fills these imperfections, or voids, and is an Excellent conductor of heat.
If the thermal paste is dried up, it looses it's thermal conductivity.
This would 'tell' BIOS that the Processor is overheating, and spin the fan at full speed.
(Needs to cool processor down)
Some manufacturers use a Thermal Pad, instead of Thermal Paste.
(Thermal Paste is also known as Thermal Grease)
A Thermal Pad is a material that is impregnated with Thermal Paste.
A Thermal Pad is J-U-N-K. Peel it off, and throw it away.
(CANNOT be reused anyway)
Use a plastic old credit card, and scrape as much of the goo off, (Or dried up paste), as you can.
Processor, and bottom of Heatsink.
Follow with Q-tips dipped in Isopropyl Alcohol. (Rubbing alcohol)
91 percent is best, 70 percent will do. 50 percent = No.
That is 50 percent WATER, and 50 percent alcohol.
Make take a BUNCH of alcohol soaked Q-tips. Needs to be clean enough to eat off of.
CAUTION!!
Isopropyl alcohol is EXTREMELY FLAMMABLE!
Use in a WELL ventilated area with NO sparks or flames present.
Now put a small pea sized drop in the middle of the Processors case.
When the Heatsink is mounted down firmly on the Processor, the paste will squish out to the proper specifications.
For additional questions post in a Comment.
Regards,
joecoolvette
(Also look at the Electrolytic Capacitors on the motherboard.
Look C-L-O-S-E. See if there are visual signs of failure,
http://www.capacitorlab.com/visible-failures/index.htm
The ones on the motherboard that have no sleeve, and a blue(?) half-moon mark on them, are polymer solid capacitors. Rarely do they fail.
The one's that have a black sleeve on them, are Electrolytic Capacitors.
These DO fail )
May 18, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
No display
Hello Abhramukherj, try cleaning the memory slot. reset CMOS and retest RAM sure 100%.
Jan 21, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Computer does not start. CPU fan tries to move and stops
your processor is overheating. if you know how to open your cpu, that would do the trick. you should check out your cpu fan and try to clean it up. maybe it is all covered with dust. it cannot let the heat go out because your fan is clogged with dust. also, clean your processor.
Nov 01, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Problems with EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0,sound drivers problem
This is the link for your mainboard driver
ECS 945GCT-M/1333
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Driver&MenuID=44&LanID=0
Feb 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
P4-2.66Mhz processor run on a ECS motherboard 945GCT-m/1333
This may sound counterintuitive but its just a suggestion. I see by your prior post you are using a PC2-4200 1GB ram stick. Have you tried using faster ram? I suspect a FSB timing issue, even though by the numbers it should be running at 533MHz (which is 5x133).
This motherboard defaults to setting the clock speed by SPD (serial presence detect) but can be set manually in the BIOS. See if you can beg/borrow a PC2-5400 stick to see how it affects the timing and performance.
Dec 31, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I have a 945GCT-M/1333 motherboard but my processor is a Intel Pentium 4 - 2.66mhz and it seems to run for a little while and then shut down the entire system. I am running a Ram chip 1GB speed 533MHz...
I always suspect overheating first in these cases. Are the fans, especially the fan on the cpu heatsink running?
You can check the system temperatures on most systems by booting the PC and entering the BIOS setup ....often by pressing the DEL, ESC or F2 key repeatedly as it starts up (the screen will tell you . which key to press to enter setup) . In the BIOS setup navigate to the "HArdware Monitor" or "PC Health" section. Watch the CPU temperature. On idle in the BIOS setup the temperature really shouldn;t go above 40C.
If it's a lot higher than this then the CPU heatsink fan needs attention.
ECS 945G-M3 PC build problems
Reading your manual: http://download.asrock.com/manual/P4i45GV%20R3.0.pdf
On page 23, In bios, select 'advanced' menu item from top, then second option below should be 'OnBoard VGA Share Memory' - set to 64MB.
Jan 13, 2008 | EliteGroup 945G-M3 Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
96 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
