Question about Nokia 3110 Cellular Phone
My Nokia 3110c is getting switched off as i try to switch on it. i have installed the software from nokia but again facing the same problem. What exactly is the problem and also let me know the solution for this.
  • Nokia Master
  • 2,148 Answers
This is a software. some files might be infected by virus in c programme and the file might corrupted.Sometimes it occur when using more of mmc more than 1gb.the phone cannot load the memory of mmc so it affected to phone.Sometimes this arises when receiving files via bluetooth.messages etc.This is due to the weakness of software.
Anyway you can solve this by using my trick
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
3110c files And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......
Posted on Sep 30, 2010
  • 1 more comment
  • Brijesh Pal
    Brijesh Pal Nov 30, 2012
    what is 3110c files ? it can't download . .
  • Brijesh Pal
    what is 3110c files ? it can't download . . . please reply
  • Jordan Raingam
    Jordan Raingam Dec 02, 2012
    Sorry.if you could not find/download 3110 files use thishttp://www.softpedia.com/progDownload/Na... Copy and paste it to command tab.Download it and install.Open the application after the internet connection is active.Select your phone model,It will again show the firmware version select the latest(highest).
Nokia 3110c enter restriction code error problem serial no--12345610654321
Try to use NSSPro SIM unlock function or Phoenix software to reflash software, you can download new software by using Navifirm Plus http://navifirm-plus.en.lo4d.com/
Nov 07, 2015 | Nokia Cell Phones
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
I cannot switch on my nokia 3110c. when i try to switch it ON, it flashes once and automatically switch OFF.
This is 100% software problem you need to flash/update firmware the phone contact mobile tech,But now you can do it by yourself if you have the requirments ..
3110c files Secondly download
Good luck.......
Sep 21, 2010 | Nokia 3110 Cellular Phone
I want to format my nokia 3110c phone
Please Try Again it:
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Format it
if Your Mobile not Format so Please
New Software install in the Phone Problem will Solved
Sep 09, 2010 | Nokia 3110 Cellular Phone
Restart my 3110c nokia phone how to format my phone with install any software
my nokia 3110 is not starting upp.whenever i try to switch on the phone a light blinks 3-4 times and than again it switch off.. so what should i do
Feb 19, 2010 | Nokia 3110 Cellular Phone
Nokia 3110c unable to switch on
reinstall your mobile software.........go to market and tell them to install your new mobile software
Dec 17, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
328 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
