Question about Whirlpool 33 in. ADP6830 Free-Standing Dishwasher
We recently purchased a Whirlpool ADP 4736 dishwasher, and just last night while it was working the fuse just blew, and we heard a popping sound at the back of the washer. We tried to replace the fuse, but the same problem. \r\nAlso, there a lot of water has collected at the bottom of the washer, although the dishes have been cleaned and dry. What could be the problem and the solution for this. All the instructions are in Polish and made in Poland. Please advise?? Many thanks Percy'
jsrock516
  • 5911 Answers
SOURCE: black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
Posted on May 12, 2007
  • 7 Answers
SOURCE: Whirlpool Gold dishwasher
It looks like there is not enough water pressure to spin the spray arms. Loss of pressure may be due to various things, like damaged seal, cracked tubes, clogged filters, screens etc.
I suggest you take a look at the technician repair sheet that should be stored inside the front panel at the bottom of the door. Remove that panel under the door with screw driver. Inside, attached to the panel, you should find a troubleshooting guide and solution for technician. But it is easy to follow. Look at the section under "poor wash" and follow its recommendation. I had exact same problem - not enough water pressure. In my case, the chopper screen was clogged and the chopper assemply was broken. I followed the repair instruction above to remove the chopper assembly, cleaned the chopper screen and the washer now is as good as new. I will need to replace the chopper when the part arrives.
Good Luck
/Dara
Posted on Nov 27, 2007
  • 351 Answers
SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: Whirlpool Dishwasher Not Working
Did you check the fuse in the plug (or fused spur) for the dishwasher?
Posted on May 17, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
My Boston Acoustic Avidea 610 home theatre receiver popped last night and lost power! it has not been able to be powered up again!
Sounds like you blew a cap or some sold state device in the power supply section of receiver. Open her up and start looking and smelling - replace bad parts and cross fingers.
Aug 27, 2017 | Boston Acoustics Avidea 610 Theater System
My dishwasher Whirlpool ADP 533-1, no heating the water. The temperature sensor NTC is OK. The relay in the electonic card is OK, but their coil no receive 12 VOLTs DC. I want de manuals of ADP 533-1
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Whirlpool 18 in. ADP530 Free-standing...
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Lost Power
Replace the thermal fuse inside the control panel.
Part #3376359
Mar 11, 2009 | Whirlpool DU960PW Dishwasher
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 33 in. ADP6830 Free-Standing Dishwasher Logo
122 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
