Question about AlloBaby Baby Gear
Lolo mo malakas - AlloBaby Baby Gear
Lyric search by words in song
Lolo - Hey now (don't dream it's over)
Aug 29, 2014 | Games
Malakas sa diesel
Anong sasakyan mo?
Feb 02, 2014 | Cars & Trucks
Malakas sa gas
The higher the CC mas malakas sa gas bro, if not then it depends in your riding style. Piga ng Piga then malakas nga sa gas. Kung worn out na carburator or piston assembly mo then lalakas nga sa gas. Sudden brake then over revolution. These are some of the probable cause sa lakas konsumo ng gas. I hope it may help you.
Jan 30, 2014 | Motorcycles
Just installed system mechanic professional and receive a message that it needs iolosystemservice had this same message on two computers
You have to start the system service for the lolo mechanic. How to start the service: my computer >local disk (c:) >windows >system32 >services or just type services into the search bar of your start menu. Select services(usually on the no 1 position of the search result) once opened, you should see the lolo mechanical service among the list of services. If you locate it, right click on its status and select start. You're good to go. Hope that helps.
Jun 08, 2011 | Iolo Technologies System Mechanic: Windows
Guys..need help...bumili ako ng CDR-KING ROUTER CW-8196..nadedetect ko ung wifi signal pero walang internet access. pero pag direkta sa LAN ung net ko.malakas naman net ko..windows 7 gamit ko...
DUDE..simple lang yan...if meron ka modem...off mo muna modem..
tapos..un-install mo yung "ETHERNET ADAPTER"
den...from Modem connect mo to CDR-king Router - PC, tapos " restart "
and MAGIC...OK na NET MO..pati WIFI...
May 26, 2011 | Computers & Internet
Pawala wala ang net ng phone,
baka sa connection mo yun try mo maghanap ng malakas na connection
Mar 09, 2011 | Cell Phones
Mahina na po kasing humatak motor ko tmx 155 siya na nakasidecar, napapansin ko kasi na pag paakyat na ako bigla siyang manghihina.. hindi tulad ng mga ibakung kasama na malakas pa rin hatak ng motor nila...
bro' kumusta,
madaming pwedeng posibilidad yan, poor compression, poor spark, poor combustion. Check mo muna yung carburador niya.. dapat ang ikot ng fuel-air mixture e 2.5 turns out. Tanggalin mo yung air box at linisan yung filter nito.. tro mo din patagbuhin panandalian na walang air filter.. kasi pwede barado na ang intake nito. Check mo spark plug at siguraduhing malinis pa ito. Panigurado e palitan mo nalang ng bago.. check mo din na dumadaloy na maayos yung fuel papunta carburador.
kung ayaw mga to, pa-compression check mo para masuri ito ng maigi baka kasi maluwag na yung piston rings or piston nito.
sana nakatulong,
parate naman kung sakaling natulungan ka nito
salamat
Dec 27, 2010 | 2005 Honda CG 150 Titan ESD
What is a earth piont
LOLO. It's what the UK calls a ground. The NEG connection. The entire body is "Earthed", or grounded.
Mar 07, 2010 | Chrysler Cirrus Cars & Trucks
Baby Gear Logo
Top AlloBaby Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an AlloBaby Baby Gear Expert? Answer questions, earn points and help others
