Question about Sansui Televison & Video
My sansui hard rock 2000 colour tv is not working properly mean to say the power is coming into the set but if I going to onthe tv is not responding always the set is in stand by mode what can I do please
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: I have a flat screen colour 74cm sansui tv
This is the shutdown circuit activating. The circuit is detecting a high current event (shorted component) and is turning off the TV before additional damage is done. Due to the nature of this problem, I would ssuggest that you have a qualified TV technician repair this TV for you.
I hope this helps,
Thank you,
Shuttle83
http//www.electron-age-technologies-llc.com
Posted on Jun 17, 2009
  • 21 Answers
SOURCE: Sir,
check the colour system of ur unit,maybe it is pal/secam or ntsc system
Posted on Mar 02, 2010
sure_thing
  • 157 Answers
SOURCE: Sir,
Does this tv dropped? if not, you may have large speaker beside it. Keep it away from magnets, speakers that are not magnetically shielded placed near your tv can cause stain(the problem you have in your tv). After doing so and still stain persist, degaussing in needed (not available as household tools) what we can do is leave it like that for quite sometime it will eventually disappear, arround 2 weeks,, not unless your tv's tube is defective. Tv's are equipped with internal degaussing circuitry but needs time to clean those stains, since it work only few sec after switching On your tv. Hope it helps
SOURCE: Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Posted on Nov 10, 2010
Hi I have sansui tv , it's colours are going to
Check and replace the chroma IC. Before replacing it, re solder all the solder terminals to this IC, by applying a little more fresh solder to each terminals.
Sep 29, 2012 | Televison & Video
My Sansui 32" Model LCD32hbw got stuck with the
Sure the power supply si working and the processor seems struck up to trigger the power but is not responding to the remote. So it is important that the main processor is checked to fulfill the working. Check for the +5 rail voltage, check for the input /output data, check the remote feed of data and the crystal oscillator.
It is possible that there is a failure around the processor or the memory.
Sep 03, 2011 | Sansui 32" TV
When I go to INPUT the sereen says: VIDEO LOCKED
Hell My Sansui Hard rock 21 eye tv has been chennal & voliume locked.
or remot not working tv screen small
Aug 25, 2011 | Sansui D 27" TV275 TV
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
In My sansui k2k21 flat tv showing red colour more please tell me will i replace the eht or crt
you do not have a CRT in your flat panel set.. What you might have is your color setting to high causing the bleed or your
T-con board is bad , but first turn down your color if that does not do it have a tech replace your
T-con board
Nov 19, 2009 | Sansui HDLCD3200 TV
How to enter into Service Mode in Sansui Hard Rock 21 eye model
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 14, 2009 | Sansui DTV2760 27" TV
Need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 31, 2009 | Radio Shack 15-2142 Remote Control
Help me please................................
Usually, once child lock is on, the set will not respond to the front panel buttons and you need the power button on the remote control to turn the TV on. Then go into the menu and turn child lock off.
Mar 31, 2008 | Sansui H TV2600 TV
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
