Question about Cameras
Hello Sir.Madam, I have DSC-H10 digital camera. It is having memory of type "Memory Stick Pro Duo". This card was working fine till the day. To transfer images to my PC, I have accessed this card to SD card reader and then after I inserted this memory card again in camera. Now I am Getting error "Reinsert the memory Stick". I thought that card may have corrupted but I can access it by SD card reader. Also I have formatted it in FAT format and then tried to use in camera but still its not working. Please provide your guidance. Thanks, Seema
    Brigadier General:
  • 3,006 Answers
Your problem is that you have formatted your MemoryStick from your computer. Your Sony camera uses its own proprietary formatting method and does not understand FAT32. You may also have corrupted your memory card if you didn't click on "safely remove hardware" or by right clicking on the icon of the MemoryStick in the My Computer window and selecting "Eject" from the drop down menu. (This assumes that you have a Windows pc, Macs will have their own way of doing this).
Try reformatting the memory card in the camera itself, this usually solves the issue but if it doesn't then you'll have to replace the MemoryStick.
Good luck, I hope that my reply has been of use and that you are able to save your MemoryStick. I'd be grateful if you would take a moment to rate my answer.
Posted on Sep 30, 2010
  • adonshik May 22, 2011
    how do you format it if u have that error?
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
DSC-H2 will not accept memory card
The DSC-H2 works with Memory Stick Duos, not with Memory Stick PRO Duos.
Nov 26, 2013 | Sony Cyber-shot DSC-H2 Digital Camera
Can sony digital camera dsc w 80 support 4 gb memory card pro duo
Yes, DSC-W80 manual says it supports "Memory Stick Duo" up to 8Gb, but there is also a comment that movies with the size set to 640[fine] can only be stored on a "Memory Stick Pro Duo" so therefore they must be compatible.
http://www.docs.sony.com/release/DSCW80.pdf
Mar 23, 2011 | Cameras
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Unable to upload pictures from memory card to computer
Most laptops that have a memory card reader will only read these types of cards, without needing an adaptor: -SD card -MMC card -Sony Memory Stick or Memory Stick Pro cards -XD cards
However, you have a MS Pro Duo card, although it fits into the card reader slot, the card is a lot thinner than what's expected, so the laptop won't be able to read it.
You need to put the Pro Duo card into the stanard size MS Pro caard adaptor. See attached image.
Hope this helps.
Jan 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Memory stick
Does your camera works fine with the previous memory card?
Sep 03, 2007 | Sony Cyber-Shot DSC-P71 Digital Camera
Which memory stick ?
Several of the Sony cameras require a high speed memory stick for 640 x 480 30fps movies. Here is a clipping from the Sony P150 specifications: "MPEG VX Fine with Audio (640 x 480 at 30fps), (MPEG VX Fine requires Memory Stick PRO media)"
Sep 08, 2005 | Sony Cyber-Shot DSC-P150 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
