Question about LG WM-2277HW Front Load Washer
LE error code only top line missing?
Did you ever get that fixed? Mine has the same error code???
  • 2 more comments
  • Anonymous May 29, 2008
    mid cycle my washer stopped working today. It's flashing a code of what looks like an upside down F and an E, so FE but the F looks upside down, or EE but the top line is missing on the first letter ? Was using HE detergent, small to med size load. I have unplugged it.
    Thanks for any help...
  • Anonymous May 31, 2008
    le code
    le code
    le code
You are right on the money. Had an extended warranty on LG from Best Buy and repairman was here this AM. Loose connection at thermistor. working fine again. You guys are a Godsend to many people... Thanks so much!
Posted on May 30, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
You are geting a thermistor error. The thermistor is located at the bottom of the tub at the front. I may be that is unpluged, or a loose connection. Thermistors rarley go bad, but it could also be a possibility. To access it safley you should remove the front panel and check the connection of it.
SGT 48
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Fix LE error for LG washer
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Oct 07, 2014 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
WHAT DOES ERROR CODE LE MEAN
Good Morning Friend, thank you for your inquiry!
I see that you are receiving error code LE on your Frigidaire washer. However, is it possible that the code is missing characters? I show that LE is an invalid error code. May I have your model number please? You can normally find the serial tag (which lists your model number) on the upper front, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand. Thank you! - Z
Jul 17, 2014 | Frigidaire ATF6000ES Front Load Washer
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
LE error code
Hope this helps.
Error Code Condition
Error Code IE Condition Inlet water supply error
Error Code UE Condition Unbalanced load
Error Code OE Condition Drain error
Error Code FE Condition Water overflow error
Dec 16, 2017 | LG WD14311RD Front Load Washer / Dryer
LE onread out on top of machine
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Aug 11, 2011 | Washing Machines
I'm getting a code that is telling me to unplug the washer and all service repair. I have a code that looks like two E's with the first E missing the top line. Is this something I can possibly fix my...
Aha the old LE error code:
Problem:
An occasional LE error but always a slow or no spin:
Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness. All is Good!!!
Manual and More Here
Dec 08, 2010 | LG WM-2277HW Front Load Washer
Lg washer shows up side down F E code
No, this is not the same as the LE code. The FE code indicates an overflow error or condition. The things to check out would be the drain and the drain line to make sure there are no kinks in it. The drain hose can get clogged with sludge and sometimes a hot wash with a 1/2 cup of vinegar will clean out the sludge. If that doesn't work, I would take a look at the pump to make sure it is not clogged with anything and that the pump impellers are good. Take a flashlight and look into the suction port of the pump. Look for any broken or missing impeller blades. If any are broken or missing or if the impeller will not move freely, the pump would need to be replaced. Hope this helped and best wishes.
Jul 31, 2009 | Washing Machines
Error code E
you may need a new transducer put on it like mine .mine had error 3 show up all the time. good luck
Jan 20, 2009 | Bottom Line Fishin' Buddy 1101 GPS...
LG WM-2277HW Front Load Washer Logo
290 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
