Question about Fuji FinePix Digital Camera
Says !PROTECTED CARD Camera won't do anything. Can you tell me why?
  • Obertelli
    Obertelli Sep 30, 2010
    Are you using an SD memory card or an xD card? Your camera will accept either, but the answer is different depending upon which one.
  • Fuji Master
  • 17,130 Answers
Make sure that the card is detecting to the PC as you insert into the cardreader If so the card must be formatted after assuring the quality of the files.
If files are not detected please use a search for finding files and deleting . Format and now try the card on the camera.
Posted on Sep 30, 2010
5 Suggested Answers
  • 53 Answers
SOURCE: MY MEMORY CARD WHEN INSERTED SAYS:PROTECTED IMAGES
there should be a little swith on the side of the card. switch to the opposite and then try
Posted on Aug 26, 2009
Testimonial: "Thank you! You fixed my problem!"
  • 102366 Answers
SOURCE: the camera reads memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Oct 01, 2010
  • 262 Answers
SOURCE: My camera is showing protected card in the face
The normal answer to this problem is to start talking about the 'lock' slider on the side of the memory card. However, your problem must be different because your camera uses the xD-Picture card... and it has no such slider! In this case, the most likely reason is that the card has been corrupted in some way, and the camera's error message is more of a general nature, triggered by some inability to write to the card. Your best bet is to make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the correct drive and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
Actually, I'd like to thank you for drawing my attention to this, because I've been advising people with SD cards that the error must be caused by the slider... however, from what I've learned now, it's also possible that their cards can be fixed by reformatting, too.
Posted on Jan 21, 2011
bigdtexan
  • 33 Answers
SOURCE: My camera says card protected
There is a tiny switch on the left side of the card. One setting is to lock it....the opposite way is to open it for taking pics. It's a safety so you can't accidentallybigdtexan_1.jpg delete any pictures, but also won't let you take any more. (see pic)
Posted on Sep 23, 2011
What does card protected mean?
Wheb you have a SD, SDHC or SDXC memory card and you put the switch to the lock position, the card is protected, That means nothing can change the files that are stored on the card. Not by wiring, not by deleting and not by formatting. Keep the lock with up, towards the golden connection points.
On the picture the 64 GB card is unlocked. `the 32 GB card is locked 8ab871eb-243a-48dd-a8d8-58e5df95d568.jpg
Dec 29, 2013 | Vivitar ViviCam 8025 Digital Camera
MY VIVITAR X018 KEEPS FLASHING CARD PROTECTED AND WILL NOT LET ME DO ANYTHING
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 08, 2013 | Vivitar Vivicam X018 10.1 Mp Digital...
Even though i have a brand new sd memory card my Fujifilm Finepix Z camera still says "protected card" and won't let me do anything at all
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 23, 2013 | Cameras
When switching on camera it keeps saying protected card and I can't do anything
Dec 24, 2012 | FUJIFILM FinePix S1600 Digital Camera
My fuji j20 keeps telling me protected card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 04, 2012 | Fujifilm Finepix J20 10mp Digital Camera...
Memory card is write protected
You should be able to read the card whether its protected or not. In fact I always protect the card before putting it into my computer so as to prevent the computer from doing anything to the card.
Feb 26, 2012 | Nikon Coolpix S3000 Digital Camera
The camera reads memory card write protected and it won"t allow you to do anything else.
Oct 01, 2010 | Nikon COOLPIX S52 Digital Camera
Aug 26, 2009 | Kodak EasyShare C875 Digital Camera
Digital camera
personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Jul 11, 2009 | Samsung L100 Digital Camera
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory1.gif card you slide up and down. I know most SD cards1.gif have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards1.gif they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
Jan 15, 2008 | Nikon Coolpix 4500 Digital Camera
Fuji FinePix Digital Camera Logo
37 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
