Question about Sunforce 1000 Watt Pure Sine Wave Inverter Pro Series 11240
Can this model be used on the grid? If not, is there a sunforce inverter that can be used on the grid?
  • 17,130 Answers
If you meant for the mains supply then it must be connected in series to the load so that in absence of power the invertor takes over and when there is power the supply takes over as it charges the battery.
So have this wiring done with the connection routed from the fuse box or main board.
Posted on Sep 30, 2010
How could I use my 1hp AO Smith C48A95A06 model motor Goulds pump using solar energy instead of grid power alone?
possible run inverter from batteries to convert to AC power make sure enough battery voltage and big enough inverter
Oct 28, 2017 | AO Smith Pool & Spa
Have Solar PVa system with 10 panels on the roof. The Inverter is an Aurora model and displaying error message "Missing Grid", can anyone solve?
There is insficient input voltage to permit connection
to the grid: the inverter waits until there is grid
voltage to carry out the parallel connection
look at page 27 here for more info
http://www.hyland.com.sg/download/systemtech/POWER%20ONE%20PVI-6.0-TL/POWER%20ONE%20PVI-6.0-TL%20Manual.pdf
you may have a different model of inverter pvi so youll find the manual
i think your output from the panels isnt enough juce as it says
or the inverter or more likely a fuse has failed
remember this is input voltage and not the connection to the grid thats been autherised
Dec 05, 2014 | Office Equipment & Supplies
4500 sun force inverter internal fans are always on. When I first set it up it use to come on to cool and then go off.
Likely the thermistor used as a thermal sensor shorted out. Either internally, or to the heat siink.
Dec 21, 2011 | Sunforce 4500W Pure Sine Inverter Watt...
My inverter keep blowing 40 amp fuses without load
Hi Trevor,
A 1000W can barely supply 5A at 220V, less than 10A at 110V. So if a 40A fuse blows, there is a serious problem and you should not attempt to use this unit after it has been checked by a qualified person. Please be careful!
Nov 20, 2011 | Sunforce 1000 Watt Pure Sine Wave Inverter...
Hi I have the Sunforce 1000W Pure Sine Inverter and everything was working fine until yesterday the remote stopped working. The inverter is about a month old and the remote has healthy batteries, I tried...
Have you tried removing the batteries for a minute and unplugging the main unit for the same amount of time together. The idea is to fully clear any settings that might have gotten hung up.
Oct 11, 2017 | Sunforce 1000W Pure Sine Inverter Watt...
Have recently purchased a Sunforce 11264 4500W true sine inverter, shipment pending. trying to find a view of the back side of it to determine the 12V service connections needed, PDF of manual indicates a...
Hi , i'm sorry but i dont really understand your question , assuming the current draw is around 45 amps then 2 /0 GA is fine , just keep your leads from your panel nice and short , the connection kits are sold by sunforce and there plenty of suitable connectors on the market
example link below
http://www.globalepower.com/Datasheets/BatteryConnectors/BatteryGlobal.pdf
Aug 17, 2010 | Sunforce 11264 4500 W Pure Sine Wave...
Sunforce 1000 Watt Pure Sine Wave Inverter Pro Series 11240 Logo
128 people viewed this question
Top Sunforce Electronics - Others Experts
Robert Hunt
Are you a Sunforce Electronics - Other Expert? Answer questions, earn points and help others
