Question about Brother MFC 210C All-In-One InkJet Printer
Hi, I'm trying to print in b&w. The printer says " no cartridge" although all four of the cartridges are in. It says "open scanner cover, then reinstall ink". If I lift the cover it then says "install cyan" When I close it, it says "No cartridge" again. Should I need cyan if I'm only trying to print in b&w? I can't print a test page. Nothing will go through. I got the printer second hand so maybe it's just not working... Thanks
  • 17,129 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts, tighten the cartriges onto the slots.
Posted on Sep 30, 2010
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
Deskjet troubleshoot My HPdeskjet 5550 won't print.: My HPdeskjet 5550 won't print. The orange light is flashing
hi..........
In this error condition, the following light pattern displays on the product control panel and a message might display on the computer:
  • Print Cartridge status light : On
  • Resume light : Off
  • Power light : On
Figure 69: The Power light is on and the Print Cartridge light blinksc02645167.gif
    hpweb_1-2_minus.gif Causes
    • The cover on the product might be open.
    • There might be a problem with one or both cartridges.
hpweb_1-2_minus.gif Solutions Follow these solutions in the order presented to resolve the issue. Solution one: Close the top cover on the printer
  1. If the cover on the product is open, close it.
  2. Press the Resume button (c01219285.bmp ) to continue printing.
Solution two: Determine the cartridge issue When there is an issue with a cartridge, a yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is. Follow these steps to determine the cartridge issue, and then continue to the next section for solutions to resolve the issue.
  1. Open the top cover on the product. Wait for the carriage to move. The yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is.
  2. Look at the drawing and then find the icon in the following figure that matches the drawing. Each of these icons represents a different cartridge issue. Use the icons to determine the cartridge issue. Figure 70: Determine the cartridge issuec02645168.gif 1 - Tri-color Cartridge Problem icon 2 - Black Cartridge Problem icon 3 - Tri-color Cartridge Low-ink icon 4 - Black Cartridge Low-ink icon 5 - Cartridges OK icon
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP DeskJet 5550 InkJet Printer
Incorrect cartridges message on printer screen c4183. help me
Complete the following steps in the order presented until you resolve the issue. Step one: Remove and inspect the cartridge
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the carriage is idle and silent.
  3. Press down gently on the top of the cartridge to release it.
  1. Figure 2: Removing the tri-color cartridgec00484998.gif
  2. Slide the cartridge out and inspect it.
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear protective tape has been removed from the nozzle and electrical contact area. Figure 4: Removing the clear protective tapec00211538.gif
  3. Reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step two: Make sure the cartridge is compatible Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, click this link, HP SureSupply . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
  1. If the cartridge is compatible, reinstall it in the printer.
    • Place cartridges marked with a triangle in the left carriage slot.
    • Place cartridges marked with a square or pentagon in the right carriage slot.
    Figure 5: Print cartridges installed correctlyc01091334.jpg Figure 6: Direction to insert the print cartridgesc01091335.jpg
  2. After verifying that your cartridge is compatible, reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step three: Clean the cartridge contacts
  1. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
  2. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: If you are removing a tri-color, photo, or gray photo print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
  3. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
  4. Clean the print cartridge contacts. Do not touch the nozzles. Figure 7: Cartridge electrical contactsc00832021.gif
  5. Clean the contacts inside the carriage, inside the printer. c00246272.gif
  6. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  7. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step four: Reset the printer
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
  2. Open the cover of the printer and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message.
  4. Disconnect the power cord from the back of the printer and wait for one minute.
  5. Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step five: Replace the cartridge If after you have completed these steps you are still unable to resolve the issue, replace the cartridge. If you do not have a replacement print cartridge, go to the next step. Step six: Print in backup mode If you do not have a replacement print cartridge, you can still print in ink backup mode until the issue is resolved. Remove the problem cartridge and print with the remaining cartridge.
  • If you remove the tri-color cartridge, the printouts will be in grayscale.
  • If after you have completed these steps you are still unable to resolve the issue, service the product.
  • If you remove the black or photo cartridge, the printer will print more slowly and the colors in the printouts may differ.
I hope this solution will helpful for you. Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful. THANKS & Keep Using fixya
Jul 28, 2011 | HP PhotoSmart C4180 All-in-One Color...
How do I change the printe ink cartridge?
Hi There!
Here's what you can do to replace the cartridge
Just open the top cover together with the scanner cover. When the cartridge carrier move in the middle of the printer, it's the time you can replace the catridge, then lift up the top cover for the cartridge carrier & then the cartridges.
In replacing the cartridges, you just have to push the cartridge down the carrier, you will hear a snapping sound then return the top cover for the carrier and the scanner bed.
Hope this helps!
Vikroks
Mar 29, 2011 | Canon PIXMA MX310 All-In-One Printer
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
What are proceedures for replacing print cartridges for Lexmark X2600 ink jet printer?
Perhaps the Lexmark X2600 User's Guide will be able to help you. To download it, click on this link: http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf. Scroll to Removing used print cartridges, Page 45, for instructions on how to replace print cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X2600 InkJet Printer
Sx415 I am unable to line up the printer head to
***hi there,il be willing to help you on that. ****
1. Turn on your Epson printer.
2. If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press Start (NX210 Series) or OK (NX410 Series).
***If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press or to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
3. Open the scanner. Do not open the ink cartridge cover while the print head is moving.
4. Open the cartridge cover.
5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
8. Remove the yellow tape from the bottom of the cartridge.
Caution:
Do not remove any other labels or seals, or ink will leak.
9. Insert the new cartridge into the holder and push it down until it clicks into place.
10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
11. Lower the scanner
12. Press Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do you change the ink cartridge on an epson DX4450? many thanks
Hi
Open the scanner and make sure its support locks in place.
Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
Press the Stop button again. If another cartridge is low or expended, it moves to the teardrop position. Press the Stop button again to see if more cartridges are low or expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right.
8. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
9. Remove the yellow tape from the bottom of the cartridge. Caution:
10. Insert the new cartridge into the holder and push it down until it clicks into place.
11. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
12. Release the scanner support and close the scanner.
13. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the
On light stops flashing and remains on, ink charging is finished.
Jan 08, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Although using canon inkjet cartridges 40 & 50
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-4
Aug 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
56 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
