Question about Makita BMR100 Radio
Gotta hole in speaker need new one - Makita BMR100 Radio
  • 17,129 Answers
Just take the speeaker along and get the correct size with the correct coil resisitance.
If you can get the paper changed by gettting the paper , removing carefully from the sides, the spider settings and the coil, refitting back to the coils and centrally placing for a free movement, glue it on.
Posted on Sep 30, 2010
My bike will not kick start u gotta pop it dosnt stay running u gotta keep give it gas
Two possibilities...1) there is a vacuum leak between the carb and the intake port on the engine. 2) you have low compression and the engine needs to be bored and piston replaced. Check compression with a gauge, then check it again after a couple CCs of oil dropped into the plug hole. If the compression goes up, ya gotta do the bore thing, often called a 'top end job'
Oct 19, 2010 | 2003 Suzuki RM 125
I am trying to install speakers in my 95 chevy cheyenne 1500, but there are no holes to screw in the screws. do i just need to make new holes? if so, how?
i would recommend just drilling new holes do not try to screw them in without first drilling pilot holes other than that you should be fine just make sure that the panel has no wiring or vital components behind it.
Jun 04, 2010 | Alpine SWS-1240 Car Speaker
Front driver door speaker is blown and needs to be replaced. how do i do it
look on ebay or junk yard for replacement, just remove the cover and replace it with another, don't recommend after market unless you going to upgrade the radio and the sound. the problem with after market speakers is the hole is not align to the factory screw hole and you will need to do some drilling and some modification just to make it fit. the speakers wires is all plug in, just remove the old speaker and plug the wire back in the new speakers, only two wires involve, positive and negative.
Nov 23, 2009 | 2001 Chevrolet Blazer
1991 XJ6 ignition barrel replacement
Remove the steering column panels and turn the key to position 1, there is a hole that is on the steering lock assembly that you need to use a pick or similar rool to puch in the hole and release the spring tension, then the barrel slides right out and make sure you put the new barrel to position 1 and it will slide right in and "click" in place. Put the panels back on and your set to go.
JPTCAT
Oct 02, 2008 | 1991 Jaguar XJ6
Stereo wiring diagram needed
well if it doesnt work pull it out rewire and put it back in. its gonna be a very easy problem that lies right infront of you. just gotta find it.
worse case senario thro those factory speakers away and put in new component speakers.
Aug 04, 2008 | 2000 Chevrolet Silverado 1500
Tx-v940
If you don't got any sound the audio amplifier IC is damaged you gotta change it.Good luck
Jun 11, 2008 | Onkyo TX-V940 Receiver
No sound
u gotta make sure all the connectors are right, The dvd player output cables are plugged into the OUTPUT of ur dvd, and they go into the Video Input of the amplifier, U gotta make sure ur speakers are plugged in into right too, out put speakers. Surround system only works on DVDs and some music CDS, so dont expext to have surround sound from all music CDS/
Feb 10, 2008 | Audio Players & Recorders
Headphone jack is finicky
Does this help?
http://www.fixya.com/support/t882518-right_speaker_stops_working
It's probably the socket - it may be that it's coming away from the board or the switch inside that cuts the speakers when you use headphones is faulty. It may be a simple resolder or you could replace the part.
Jan 30, 2007 | Harman Kardon HK19.5 Computer Speakers
Makita BMR100 Radio Logo
113 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Bill Boyd
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
