Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I bought second end whrilpool fully automatic washing machine not working
  • Whirlpool Master
  • 17,130 Answers
Can be several reasons, starting from the power supply to the control board, if there is no action on the control board then you have to change the board, if the control board reacts to the program settings, it must allow inlet valve to open. the waterlevel sensor to work and the motor to click for starting cycle..
So check and respond.
Posted on Sep 30, 2010
My whirlpool Fully automatic washing machine is not functioning properly,what can I do to repair it?
Check to see if the machine has touched the on off tap at the back during spinning and cut off water supply.Or check the penny trap at the bottom of machine.if both are okay the it is likely to be down to faulty board or impeller motor which helps the flow of water into machine.
Nov 19, 2014 | Whirlpool Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
My whrilpool duet is lockt on control... I can not change, cancel or do anything, The only light on the waser is 'Controle 'Loocked'
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Utomatic washing machine cannot drain the water
see if theres not something clogging the pump on ht e machine
Nov 02, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
226 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
