Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
Hi, anyone know the part number for the lense cover? (its the one that flips open)
  • Sony Master
  • 17,130 Answers
Best advice is to get this shown to the sony service to replace or order accordingly and you can change with them or otherwise.
Anyway the part can be ordered only from Sony.
Posted on Sep 30, 2010
Instruction on how to change headlight bulbs on 99 gmc yukon?
You may have to get to them from under the hood behind the light unit.
Mar 18, 2013 | 1999 GMC Yukon
Don't know what motorolo mobile I have it is a flip cover
Usually the model number can be found under the battery. Remove the back panel and pop out the battery. Look for a tag containing model number, serial number, etc. Pop the model number into Google and it will tell you the name of the phone.
Jan 07, 2012 | Motorola Cell Phones
Re Sony Cyber-shot DSC-T7/S Sliding lense cover wont travel down far enough to clear the lense. Message on screen says --lense cover closed Sydney Sony repair centre says discard for new. Seems a...
Hi your camera is very simply in mechanically. It may has loosen screws go around and stuck inside. If you are careful, you can try on open and look for the piece. If you are willing to, then let me know. Thanks and best regard!
May 25, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a DCR-HC30 Sony Camcorder but I open the lens cover but I still can't see through the lense it still says cover not open
This is problem of ccd imager chip failure in your DCR-HC30 camcorder and ccd imager chip will be replaced to get live view in camera mode.
Let me know if you want to replace ccd imager chip by yourself if you know soldering parts in circuit board and can apart camera safely to provide you part number info OR take camera to qualified tech for fix.
Thanks.
Dec 01, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
I have the same problem
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 23, 2009 | Samsung Digimax S630 Digital Camera
Toshiba 50H81 access to lenses
Hi Dan,
I emailed you 2 ideas, how to get approach lenses for focusing.
Hope that would be helpful to you.
Dec 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Lens cover jammed open.
No send it back they are the only people that will deal
More over - the likely cost will be very near the cost of a new high spec camera.
Jul 21, 2008 | Fuji MX-1700 Zoom Digital Camera
Canon L100 fax machine
Just flip the little key cover open on the right hand side of the machine then press "Data Registration" then press "Set" then press "Set" again this will put you on time & date setting if you press "Set" a third time you can now change the settings using the arrows to step around and the numbers to change the settings. Just press "Set" when finished to save your setting & press "Stop" to exit programming mode.
Oct 30, 2007 | Canon FAX-L1000 Plain Paper Laser
Retractable Lense Does Not Open
This thread might be relevant to your problem: http://www.fixya.com/problems-solutions/t114846,p220455/Olympus-Digital-Cameras.aspx Comment on what you saw in there when you opened it up, compared to the other user. Good luck
Jun 21, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
