Question about Yamaha P-3500 Amplifier
A yamaha ps3500 amplifier switches on but does not give sound output
  • Rommel Cana
    Rommel Cana Oct 01, 2010
    check power supplies rails, regulators on both preamp and power amps,
    Check for DC out on each.
    here are sample troubleshooting guide:
    http://www.fixya.com/support/r4008719-di...
    these may not be the same as yours but the principle in troubleshooting is the same
    Genius:
  • 1,175 Answers
HI...
If all the speakers are connected properly then,
There is at least 1 output amplifier failure.
It will need service
Posted on Oct 04, 2010
It is getting no sound. What should I check first?
first check it is getting power. does it light up? is there power to the switched AC outlet in back?
May 23, 2014 | Yamaha DSP-A1000 5-Channel Amplifier
DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Apr 26, 2010 | Audio Players & Recorders
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
Ps output +29.9v, -8v = no sounds. any ideas ?
Can you post the model number please. I have some Yamaha service info, but each model is different.
Thanks,
Dan
Jan 13, 2010 | Yamaha Audio Players & Recorders
I have a Yamaha RX-797 reciever and wish to install an outdoor speaker system through the zone2 outlet. Do you know if I can go from the zone2 outlet through the coupler jacks to the speakers so I can...
Hello sounds like you want to take the low level zone 2 output and run it to the PRE AMP in?
If that is correct the onboard amplifier will power your speakers but will no longer provide sound for your main channel as you are removing the "loop" which send the front L & R signal to the amp.
Your best bet is to find an inexpensive secondary amplifier.
Sonance makes a sonamp 260 or 260x3. These are available on ebay for under $100 and work great for multiroom applications.
A 260x3 would give you 3 speaker outputs allowing you to run not only to your patio but also to two other locations and includes a switch to turn each zone on/ off.
Hope that helps
Jan 02, 2010 | Yamaha RX-797 Receiver
My DVD player quit working. It was plugged into my Yamaha amp. I hooked up another dvd player, I get sound and no picture. When the dvd player is connected directly into the TV there is picture & sound. I...
Try using the composite video or SVHS video outputs on the original DVD player with the Yamaha amp. The other DVD player might have a switch on the back to select composite or component video outputs.
Dec 13, 2008 | Audio Players & Recorders
Which operational amplifier is good for output of sound card ?
I use an 80 watt yamaha with sub woofer but there is several good ones out there.There is Logitech, Philips, Bose and J.B.L. that's just a few but these are about the best ones.
In Christ Greg
Nov 17, 2008 | Aardvark Direct Pro LX6 Sound Card
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha P-3500 Amplifier Logo
264 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
