Question about Ardisam Inc Earthquake Mini Cultivator
MC43 Engine difficult to start, floods easily, have to remove spark plug and 'blow" the excess fuel out of the cylinder (as directed by manufacturer's technical support on the telephone). This is when you try to start it by the owner's manual. Don't dare press the primer bulb if it is already full of fuel, even when it is cold. Try to choke start it first then recheck the bulb if it doesn't start. Is this normal for the Viper MC43 engine?
2 Suggested Answers
SOURCE: i am needing agas primer
Go Here. http://www.getearthquake.com/foundations/store/partsblowup.asp?product=MC43
Posted on May 09, 2011
My cub cadet sc 100 won't start after putting it on it's side to sharpen blade.
Since you put it on its side, you most likely dumped all the oil from the crank area to the cylinder and carburetor. What you need to do is check engine oil to be sure it is full. Then take air filter off, clean the carburetor with carb cleaner. Remove spark plug, clean spark plug with carb cleaner. Pull the cord about a dozen times WITH THE SPARK Plug removed. Then install spark plug and try to start.
Feb 15, 2017 | Cub Cadet Garden
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Why won't it start?
it is flooding . turn off the choke and remove the plug
dry the plug and pull the rope about 10 times to blow all excess fuel ot of the system
refit plug and try it again
May 02, 2015 | Garden
Won t start
If the plug is wet, it is likely fouled and the cylinder flooded. Dry off the plug and reinstall it. Open the choke and throttle so the carb throat is wide open and crank the engine over. This will evacuate excess fuel out of the cylinder faster then anything. It should fire at least once.
Nov 10, 2013 | Tecumseh Garden
My presuure washer was running fine while we were moving it , it started smoking and shut off now it won't start
if the smoke is black too much fuel from carburetor enter causing it to flood ,remove sparkplug pump out excessive fuel in cylinder re install dried spark-plug and try again be careful not to hole pull-rope handle tight allow it to break free from hand if and when the engine can build up excessive compression and pull-back rapidly.if smoke was blue then its oil,check carb intake by removing air filter
Aug 03, 2013 | Honda Garden
Very difficult to start, new battery, new starter Gas in the cylinder flows out when you remove the spark plug
Your engine is flooding due to the carburetor float and needle having a problem. Do not try to run you mower like this. The fuel gets in the oil, where it acts like a thinner removing oil from critical surfaces. Remove the carburetor, disassemble, inspect and correct the problem with the float and needle. Change the oil, put fuel in tank and monitor level, remove the spark plug, check fuel tank level, turn engine over several times to get fresh oil in place, reinstall spark plug, check fuel tank level (ensure stable level), if all is good, try starting.
I hope this helps.
Aug 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Daewoo dont want to start after we overhaul the engine. It seems that engine is getting to much fuel. The spark plugs 1 and 3 are wet with fuel and when I pull out these plugs the car starts and the...
As mentioned by you the fuel discharge is too much which seems to FLOOD the cylinders and so makes the firing difficult. So the fuel tuning must be done to ensure the correct pressure.
Also check if the spark intensity is good as if there is no spark there will be fuel flooding.
Have the fuel pump calibrated and the injectors checked, if not replace.
Aug 23, 2011 | 1999 Daewoo Nubira
Spark plug flooded by fuel
This is due to the fact that the engine is not igniting and so the fuel excess leads to the flooding within the cylinder. Now remove the spark plug and manually pump out by starting the engine. Hold a piece of hard cloth on the mouth of the spark plug thread and crank. You hear the air pressured out with the flooded fuel. Now check the spark plug gap and the spark intensity. if bad replace the plugs.
Finally check the fuel /air settings on the carburater, this must be tuned properly.Finally check the fuel filter for clogging.
Jul 22, 2011 | 2011 Hero Honda Splendor Plus
Very hard to pull start.
Two possibilities--one, the engine is flooded and the spark plug needs to be removed, then open the throttle and pull the engine through smartly several times to expel excess fuel. Check the air cleaner for plugging. Second, the engine may have been run without oil in the fuel which will result in the piston /ring(s) scoring itself and the cylinder wall severely. Remove the muffler and watch the piston as it travels the cylinder while pulling the engine through slowly. Any heavy scoring will necessitate replacement of the cylinder, piston, and ring(s)--an expensive process if you farm it out. Hope this helps!
Nov 09, 2010 | Garden
It's flooding how can i fix it
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Overfuel or 'rich' condition
Basics to check:
b) is there spark
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes remove to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Nov 26, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Ardisam Inc Earthquake Mini Cultivator Logo
79 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Shehu Pro
Shehu Pro
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
