Question about Pc Ware PCCHIPS M766 LMRT (MB-766LMRT) Motherboard
Jumper configuration - Pc Ware PCCHIPS M766 LMRT (MB-766LMRT) Motherboard
I want to know the Jumper settings (Master and Slave) for IBM Travelstar 15 GB Hard drive. I would be glad and thankful if you will solve this problem for me. Ari Kiviharju
This solution will reference the picture below:
To configure the drive in Master mode, no jumper setting is used (Figure A1).
To configure the drive in Slave mode, the jumper must be placed over the two vertical pins on the far right (Figure A2).
To configure the drive in Cable Select mode, the jumper must be placed over the two pins in the bottom row (Figure A3)
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Computers & Internet
I want to disable the system password on my dell computer
I assume that you have the password? Restart your computer. As soon as you see the dell screen, hit the f2 key. This will take you into setup. Look through the different menus and you will find the password options somewhere. You should be able to disable it there.
Mar 02, 2011 | Intel D865GBF Motherboard
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
What is the purpose of the diagram of jumper setting?
The jumper settings (if this is the one you are speaking about) are for clearing the BIOS (times, dates, hardware etc...). The diagram is probably showing the settings on which pins to jump when clearing.
Hope this helps.
Nov 09, 2009 | Intel D865GBF Motherboard
'Turn off power and reinstall the jumper in normal mode'
go to this site to visualize the motherboard layout as i'm about to describe below. Refer to pages 12-13 http://www.intel.com/assets/pdf/prodspec/dg31pr-tps.pdf
Note: Make sure to shut down your PC and unplug from power source.
- Look for Bios Setup configuration jumper block (the one marked X on the motherboard layout)
- You will see 3 pins with a jumper connecting 2 of the 3 pins.
- Ensure that the jumper is connected to pins 1-2 to set it to Normal mode
please refer to page 53 of the pdf file to check the pin configuration of the jumper block.
Jun 22, 2009 | Intel DG31PR Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Can I use a WD3200AAJS as a slave drive. If so what is the jumper configuration.
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such.  There is a connector block on the back to configure other options such as spread spectrum clocking.  Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back).  A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
Jan 07, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Pc Ware PCCHIPS M766 LMRT (MB-766LMRT) Motherboard Logo
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
