Question about Villeroy & Boch Home
Slow leak of water into the bowl from cistern.
  • 43,501 Answers
You can buy a new flapper for less then ten bucks and changing it takes two minutes... this will stop your problem
heatman101
Posted on Sep 30, 2010
5 Suggested Answers
  • 61 Answers
SOURCE: Water leakes continually into the toilet bowl from
You need to replace the flush valve (flapper) in the tank
Posted on Jun 28, 2010
Geekman
  • 32281 Answers
SOURCE: Hello I have a 'back to
The flush mechanism has a large rubber washer over the outlet.
This washer seals the flush outlet and allows the cistern to fill up. If there is a continual water leak into the bowl then this washer is worn and needs to be replaced.
This washer is a flat ring type approx. 50 mm in dia,
Posted on Mar 27, 2011
gasman44
  • 83 Answers
SOURCE: When cistern fills with water it leaks into the
This is caused by the 'syphon' mechanism sticking, quite often nowadays the 'brilliant' plastic push button/ syphon combo sticks, and most toilets are fitted with an internal overflow, lift the lid on the cistern and check for anything causing an obstruction.
More often than not, it's a tiny bit of scale that causes such a headache, and the fact that nothing is made with any quality nowadays!
If you can't see what's wrong call a plumber, he/she will solve it.
I hope this helps
Steve
Posted on Jul 10, 2009
co7196
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
Cistern leaks into bowl
Depends on the country you live in, but in North America, you need a new Flapper in the bottom of the system. Cheap to buy and take 10 minutes to fit.
Pictures and video of them.
Cistern Google Search
Nov 07, 2016 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Water level too high in Gruppo Italia in-wall cistern
check if mechanism that releases water when you flush is tight so no water escapes.
As for water level, you can adjust to less in the tank.
Jul 27, 2013 | Kohler Toilet - One Piece with Ingenium...
Stylus cistern flushes by itself occasionaly
There is water leaking into the bowl. When the water level gets low enough, it calls for refilling the tank. Leaky valve or worn down washer in the cistern.
Jan 09, 2013 | Home
Slow leak of water from cistern. how do i fix? got part how do i fit it?
leaking from the fill valve under the tank or running into the bowl via the overflow tube? please be specific:)
Jul 28, 2011 | Villeroy & Boch Home
Cylpso Toilet Suite D-18156 Slow leak into bowl
You need to replace flapper which is available at where plumbing products are sold,even walmart has them.
Jun 10, 2011 | Kohler Plumbing
I have a leak around outside of the bowl which I suspect is due to a leak between the cistern and bowl/pan connection but can't figure out how to remove the cistern from the pan? There don't appear to be...
you should have two bolts going through the tank connecting the tank to the bowl , inbetween those bolts is the pipe that the water flows through from your tank to your bowl , this pipe has a gasket on it. if the bolts are loose on the tank it will cause that gasket to leak, you have to take the bolts off and get a new tank to bowl gasket, any plumbing supply place should have some for you , you will want to get new tank to bowl bolts ang gaskets for that aswell or you will have problems with those leaking too when you put it all back together!
Jul 31, 2009 | Home
Problem overflow valve
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Mar 04, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Home Logo
640 people viewed this question
Top Villeroy & Boch Home Experts
J.D. Browning
J.D. Browning
Lisa Zhuo
Lisa Zhuo
Level 1 Expert
Are you a Villeroy & Boch Home Expert? Answer questions, earn points and help others
