Question about Kenmore 46462 Front Load Washer
Item in washer
I washed a underwire bra and the wire came out and went into the inner works ... how do we open it up and get it out from under the drum?
  • 177 Answers
Can you see it? does any of it stick into the wash tub?
Use a good flash light to look for it. when you find it and if your LUCKY you maybe able to pull it out with a pliers.
Do Not use the machine until you get it out. It could cut the tub and cost you $$$$ to repair or worse replace.
If you cant find it, call a service company to make a service call.
Posted on May 26, 2008
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Sep 14, 2015 | Miele Touchtronic W1213 Front Load Washer
Washer say on screen LE and will not turn.. Also when manually turn the turn hear grinding noise too.
Grinding noises are bad. If you are lucky, you got an item (like an underwire support from a bra) between the inner and outer tub, which may be removed through the heater or drain openings in the tub. If you are un-lucky, your rear tub seal failed, causing the rear bearing to fail, or the shaft broke loose from the 3 arms of the spider which drives the inner wash tub. Either of those things is $$$ and a lot of work to repair, involving removal of the outer drum, seperation of the outer drum halves, and repair. (translation: minimum 2 hours labor if you've ever done one before)
Feb 28, 2011 | LG WM-2277HW Front Load Washer
My washer makes a click noise 2 times per rotation on the spin cycle. Even when empty, when i turn it the same noise happens.
typically a bra wire under the drum will cause this noise. a faulty motor will do it but with 10x more clicks . so look for rogue underwire.
Nov 09, 2010 | Washing Machines
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
If filter cap is broken how do i open it on my bosch washing mach
I had the same problem. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug any worse (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
Mar 29, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer sounds like marbles are in it when it spinns
look for an underwire bra wire it will be sticking in the drum
if you cant find it through the drum you may be able to reach whatever is causing the noise through the heater element opening in the tub
Feb 16, 2009 | Bosch WFMC 3200 Front Load Washer
Bra underwire stuck
disconnect from electricity. take back panel will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Lost a underwire from a bra
Bra underwires are one of the main engines of the appliance repair buisness.
You do need to keep a close eye out for it in the filter but it probably will do no good to call for repair. The repairman most likely will check the filter and tell you to call back if you have any trouble. Until it works it's way down there isn't much you can do without disassembling the washer.(no small feat for some of them) The only real damage that may occur is if it pokes a hole in the drain hose between the tub and pump. This has happened, but rarely. They will usually make their way to the pump and you will hear the noise, at which time you can usually remove it with no trouble.
Be sure to wash bras in a delicates bag on delicate cycle in the future.
Hope this helps.
Nov 06, 2007 | Washing Machines
Renegade bra underwires
It probably get between the clothes tub and the outer tub. If it gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove it through the port. To access to it, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Good luck !
Sep 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine Drum rattles
It is probably between the clothes tub and the outer tub. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Aug 03, 2006 | AEG Lavamat W1050 Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
 Brian Main
Brian Main
