Question about Microsoft Xbox 360 Console
My xbox 360 tray in does not open or close it only moves about an inch, how can i fix it
  • 4,102 Answers
Hi the only way of fixing this is to take the drive out and strip it down and give it a good clean, if you have any warranty left take it back and get the xbox exchanged, if you have no warranty then get someone to do it for you as its not easy to take the xbox apart let alone get the dvd drive apart.
one thing you can try is go to a computer hard ware store and buy a can of compressed air then press the open button for the drive then pull it out all the way and switch the xbox off at the mains with the tray open,
then give the inside a good spray through the flap with the can of air doing this will remove any build up of dust and it may solve your problem.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 30, 2010
Tray will open but when it closes it will make a gridining nioce
Your problem is your system was moved when your disk was in your system, happens to a lot of 360 users. Its b/c there is no protector for the disk (protector holds the disk is place so it dont fall out) I would google search "How to fix...(your problem) or do that on youtube.
Apr 03, 2015 | Microsoft Xbox 360 Console
Tip
How to fix the "open tray" error on Xbox 360
When ever you have a problem with your Xbox 360 always do these steps first:
1. Turn off your Xbox 360
2. Unplug all of your cords
3. Plug your cords back in
4. Turn your Xbox 360 back on
1. Now with your Xbox 360 on open your tray.
2. Hold your tray open while you turn Xbox 360 off making sure it doesn't close.
3. Still making sure your tray doesn't close turn it back on.
4. Have fun!!!
If this does not work you will have to send it into microsoft to fix. If your warranty is up you will have to pay $150 to fix it. Otherwise it's free
on Apr 20, 2010 | Video Game Consoles & Games
How do I fix the open tray error
It's probably the sensor that tells the system the tray is closed. Here is a video that will help you.
2013 All open tray error and no disc spin fixes Xbox 360
Jul 25, 2014 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My 360 does not read disc, everytime i place disc in ,it says open tray
I fixed this for me today. I opened the tray, and took the disk out. Just inside in the middle there is a small disk that rotates. I just rotated it a little with my finger to get it moving. Once it started spinning the disk tray closed on its own. I then put a disk in and it started reading it. I guess the piece that moves the disk got stiff and just needed some assistance. Hope this helps.
Aug 17, 2010 | Microsoft Xbox 360 Console
How do i fix the disk drive on an xbox 360
http://www.pakgamers.com/forums/xbox-hardware-faq-guides/6157-how-fix-open-tray-error-another-solution.html
ezinearticles.com/?How-to-Fix-Xbox-360...Red...Error&id... -
forums.xbox-scene.com/index.php?showtopic=484726&st... -
OK use those links above i am sure you will find help there.
Mar 25, 2010 | Microsoft Xbox 360 Console
My xbox 360 disc tray wont open how do i fix that problem
Slap the top of the the box as you press eject. that will get it open.
then wipe a little rubbing alcohol on the black belt
just under the tray . And a little petroleum jell in the
tracks under the tray . Then open and close the tray to
work it in.
Rob
Sep 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 starts up randomly, tray opens and closes spontenaously
I have the same Problem my X box came on spontaniously and the DVD tray opens and closes non stop till I get the RROD code. it will play games and DVDs only if it stays closed long enough to start then it opens up and starts the cycle all over. I opned up the DVD drive and can't see any thing blocking any thing I even used a Q tip to pit a little oil on the screw meckanisim that opens the drive and blue it out with compressed air. and it did not fix the problem I am going to have to buy a new drive my Drive is a Philips drive.
Nov 21, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
64 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
