Question about Panasonic Lumix DMC-LZ2 Digital Camera
I want to know that how many minutes there is when u put 2gb memory chip on the Panosonic f2 camera,When you do movie.
  • 4,924 Answers
It depends on what kinda format you choose the camera to shoot on ...usually if you choose avi (mpeg 4 ) .(if you have a movie in div x format you manage to see that a ful movie is usually up to 700 M) ] .than its not a matter of minutes but hours..up to 3 or 4 hours..but you will need batteries to spare ..cause on this model those 2 AA batteries will not last in video mode more than a few minutes..If you use accumulators..the time is a little longer until they will drain out but still will not shoot an hour and will be drained....
Posted on Sep 30, 2010
  • Catalin Turcu
    Catalin Turcu Sep 30, 2010
    by the way ..also depends on the resolution you use...a larger one will take more space ...
Sandisk micro memory chip not working in my lg620g cell phone
The LG620g works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work in this phone. You need to use microSD cards, 2GB and smaller.
Nov 30, 2012 | SanDisk 8gb Micro Sd Memory Card Class4...
My Nikon Coolpix L18 shuts off automatically whilst im recording video. Please help!
Regardless of the size of the memory card, the largest video file you can create on the L18 is 2GB. You can stop recording one clip and then record another and another, and then combine them on a computer to create longer clips.
In a Hollywood movie, you seldom see individual scenes as long as five minutes in length. They're usually put together from much shorter clips, changing viewpoints and camera angles.
Nov 22, 2011 | Nikon COOLPIX L18 Digital Camera
I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put the chp in it reads memory full. The chips work in anything else but wont work in the camcorder. How do I fix this?
Whats the size of your SD Micro chip? Is it 4GB or larger?
You probably bought a SD-HC chip (wich includes 4GB and larger chips). Any SD card that is bigger than 2GB is in this HC-format and will only work if the device supports it.
As you can see here in the description, your device does infact only support SD cards up to 2GB. http://www.amazon.com/Jazz-DV151-Digital-Video-Camera/dp/B001F7MXJS
I guess you will need to use smaller ones in order to make them work with your camcorder.
Best regards from Germany :)
May 02, 2011 | Video Cameras
I have a Sony Memory Stick Duo Adapter with 1 GB Memory Stick Pro Duo insert. When I put in my DCR-TRV18 camera and switch it to Memory, I get Memory Stick Error on the screen
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be the same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Dec 27, 2010 | Sony Handycam DCR-TRV18 Mini DV Digital...
Card reader always says memory card error
This camera will not accept high capacity mem cards. You are limited to the 2GB size, but that is not much of a limitation since this 5 megapixel camera can be set to put more than 2,000 pictures on a 2GB chip.
Perhaps I am not understanding your question. Are you talking about the camera giving a "memory card error" message or some other device?
Aug 10, 2010 | Canon PowerShot S2 IS Digital Camera
I have two sd cards that are brand new on is a pq1 4GB sd hc and the other is a pny optima 2GB sd when I put them inmy camera it says filesys e00100 what is it?
I own a Nikon D5000, that has a 'pqi 4GB SD HC' memory card inside.Within this camera is also something called movie mode, in other words I can record short movies. Now here is the problem, Nikon says how much I can record on the memory card, depends on the speed the memory card records. According th them, I can only record 5 minutes on a 2GB memory card. Does that sound right to you. P-l-e-a-s-e I need help in understanding this.
If this is true,......what side memory card (HD if possible) would I need to record 30 minutes in the movie mode. Thank you so much for your help.
May 16, 2010 | Cameras
Dont know how too put it in the camera
please tell us about your camera make/model?
Apr 03, 2010 | PNY 2GB microSD Memory Card
Can i upgrade the memory chips so my i tunes movies will play correctly
go to www.crucial.com and click on 'scan my system'. It will tell you if you can increase the RAM.
here are the specs
2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR333/266/200)
Maximum memory : 2GB
It may be your video card, this is an old low end motherboard so it will struggle playing HD movies.
Mar 05, 2010 | PC Chips M825G Motherboard
Problem with a memory stick
You need to format the memory card within the camera, else you will receive this error.
Apr 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Compaq presario c714nr upgrade memory too 2gb laptop
http://h10032.www1.hp.com/ctg/Manual/c01301275.pdf
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB. I would believe that infers a pair.
Dec 18, 2007 | Compaq Presario 700 470024-192 Notebook
Panasonic Lumix DMC-LZ2 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
