Question about RCA RP-9316 Boombox
How to get in to clean the lens for RP-9316 Boombox
Like other problems relating to this boombox, mine doesn't seem to be able to play CDs (It doesn't recognize them). When I listened to the lens, it did make a ticking sound, which you said was good. You then suggested that the lens should be cleaned. After trying and trying, I'm still not able to get into the stereo system. I've tried unscrewing all of the screws to get in, but I'm still not able to. Do you know how I could get in the stereo without breaking anything?
Also, could I just use a CD cleaner instead of manually going into the boombox to clean the lens?
Thanks!
  • Shoostar Jan 04, 2009
    Thanks! It now works great!
I had the same issue. Over time, the cd player quit palying at all. The unit would try to read the cd but couldn't and then skip to the next cd.
- I took fairlane's advice and put a cd in and listened for the ticking sound to indicate that the laser was trying to read the cd. I also looked inside through the top "vent" area to be sure the cd was actually spinning. It was spinning and I heard what I thought I was "ticking" sound so I guessed that the laser needed to be cleaned.
- I took off the 6 side panel screws on the right side of the entire unit and loosened the screw on the backside off the unit about halfway down from the top that also held the side panel on.
- I then removed the side panel.
- I then removed the 2 screws on the top side of the other side panel and the screw in the top center back of the top panel and was able to remove the top cover that is over the unit. The top cover is "pressure fitted" in so be careful as you try to remove it, using a little wiggle at a time, but it does comes off.
- Once you have the top off, there is a screw in the center of the plate that holds the tray for the cd's. Remove the screw and you will able to lift and spin the tray to have clear access to the laser
that needs to be cleaned. (Note the position of the numbers on the tray so you put it back the right way.)
- The laser is a little "glassy" looking thing about the size of the head of the q-tip.
- I used the q-tip with 70% isopropol alcohol and rubbed it over and around the laser as best I could. I repeated the procedure 2-3 times and the used compressed air to dry it off.
- I put everything back in place in the reverse order I took it off, based on what's in the above steps.
- Remember, the top will fit in with pressure so don't get anxious as you try to get it in the right position.
The cd's actually play again.
I hope this will help someone.
Posted on Jan 03, 2009
  • paulsod Dec 04, 2010
    Finding this was great. A lot of dust had accumulated on the laser. I had to take both sides off to get the top off. The disc was not spinning when I looked through the event area. After cleaning the laser the disk would spin, it must not start the motor if it cannot see some reflection from the CD.
Why is my jvc boombox playing CDs with squeaky noise
Did you try different CDs? sometimes it's just one particular CD.
Try to solve it by cleaning optical reader wirh a CD cleaning kit
For your better information look up this site
Memorex CD and DVD Lens Cleaning Kit
May 14, 2015 | JVC Audio Players & Recorders
What is the universal remote code for an RCA RP-9316 Audio system?
Please let me know what brand your universal remote is and the model so I can further help you. Usually, there is a sticker under the battery cover that tells you what model it is. I would be glad to help.
Sep 16, 2014 | RCA RP-9316 Boombox
RCA RP-7979 - what is the small black piece that the CD snaps onto inside CD player?
You probably are missing the hub. Your CDs won't play without it
Jun 25, 2013 | RCA RP-9316 Boombox
The signal is not very good
Yes purchase an Y fm antenna wire, and attach spades to terminals on the back, if not available! attach one wire to antenna rod, and don't forget to put Y lead on the wall for maxium range.
Mar 01, 2012 | RCA RP-9316 Boombox
Our Insignia Boombox does not detect the CD. CDs are placed in the Boombox face up, but it continues to say "no disc."
I hope you mean "label side up" since every boombox I have ever seen plays discs face down. If you are putting them in upside down, your CDs certainly won't be detected. However, maybe in yours the CD does need to go in that way.
If you are putting the discs in the right way, the lens on the laser pickup may be dirty. You can try a cleaning disc, but these often don't do any good. And in some multi-disc players they can even jam and cause damage. It's usually best to clean the lens with a cotton swab and lens cleaner.
Another possibility is that the pickup is just too worn out to play anymore. If this is a new problem and it's not because of dirt, the pickup may need to be replaced. Over time the laser power drops, and when it gets too weak there isn't enough light bouncing off the disc for the pickup to register it. Pickups are replaceable, but depending on the part cost and the work needed to get to it, it may be more economical to replace the boombox.
Dec 16, 2010 | Insignia Audio Players & Recorders
Need the manual
There are two sites to download the pdf version on your manual.
RCA RP9316 Specifications
OR
RCA RP9316 Manuals Support and Troubleshooting
Hope it helps :-)
Apr 28, 2010 | RCA RP-9316 Boombox
When I want to play a CD the read out says ''rEAd''.
Its trying to read the cd. Sounds like you have a problem with a dirty laser or a incompatible disc. You can try getting some rubbing alcohol and a qtip dip one end of it in the alcohol and then rub it on the laser lens in a circular motion. Let the lens dry and try playing a cd again. Hope that helps.
Nov 25, 2008 | RCA RP-9316 Boombox
CD Player Issue
the system has problems reading burned CD's u cant fix it or anything windman
Jan 30, 2006 | RCA RP-9316 Boombox
RCA RP-9316 Boombox Logo
494 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
