Question about Canon PIXMA MP240 All-In-One InkJet Printer
Alarm light is blinking and i am not able to do anything with printer. pls help me. on monitor it is showing that paper jam press ok button. i did the same but still the problem is same.
  • Canon Master
  • 17,130 Answers
We can try a reset so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
if this wont help check the main board has errors.
Posted on Sep 30, 2010
  • gaurav_ga200 Sep 30, 2010
    without connecting printer to PC it is also not working. still alarm light is blinking
  • Donald DCruz
    Donald DCruz Sep 30, 2010
    Possible fault in the mother board, check the connectors, the indetect opto sensors for paper feed..
Alarm light blinking and it keep showing E3,when i want to print,it keep asking me to remove the jammed paper,but i've checked 101 times!! no jammed paper
If the paper out tray is closed or not fully opened, then open it fully.
If that doesn't fix it, then the printer may believe that paper is jammed. You've already checked for jammed paper, so reload the paper supply and press the BLACK or COLOR button.
If that doesn't work, then disconnect the power for a few minutes and reconnect.
If that still doesn't work, there is probably a bad paper sensor or controller board.
Is your printer still under warranty?
Jul 13, 2014 | Canon PIXMA MP190 All-In-One InkJet...
What is error 5200 it shows up blinking alarm light when i turn on computer and doesnt print at all
This is a paper jam error.
Once you clear the jam press the on button for 5 seconds.
Mar 31, 2011 | Canon PIXMA MX310 All-In-One Printer
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2011 | Brother HL 1240 Printer
Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Mar 25, 2010 | Canon Office Equipment & Supplies
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Error of ip1880 printer
simple press the orange button til the light turns green; the take out d cartridges and place it back in place; restart ur printer and it should be ok.
Jul 26, 2008 | Office Equipment & Supplies
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
109 people viewed this question
old marine
old marine
