Question about Infinity BassLink II Car Subwoofer
Infinity Basslink II with LOC produces distorted sound???
Okay, I have an Infinity Basslink II installed in an 04 Acura TSX. I have left the unit hooked up to the battery, ground, and remote for about a week with no problems. It stays powered up, turns on and off with the remote wire as it should. Problems is, when I installed it a week ago and connected the RCA's, it sounds as if it is overpowered and distorted (extremly loud compared to the rest of the system) and if I turn up the headunit slightly, it blows the 20 amp fuse in the amp. You can hear music faintly in the back ground. I wanted to ensue everything else was hooked up correctly, hense why I left it all hooked up for a week without the RCA's. I have used a line output converter that states that it is a high / low impendance adapter level converter, dual channel, full DC isolation,input 10 ohm; output 10k ohms, and adjustable level control. Thr LOC is connected to the rear 6x9's and the polarity is correct. Tried differant RCA's, same response. What is the problem here? I've installed this unit before in a differant vehicle, worked great. Is the LOC the problem? Wrong amount ohms? The TSX has the factory amp, is this messing with the Basslink through the RCA's? The sound is the only issue when you plug in the RCA's. Any Idea's...
  • euroR May 25, 2008
5 Suggested Answers
  • 3130 Answers
SOURCE: LED lights up but! ???
Sounds like there is a problem with the amp. Try switching the inputs around for that output on the amp. If that does not help, Yes I would have to say that there is a problem with the amp output circuit.
Posted on Nov 06, 2007
  • 199 Answers
SOURCE: No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Posted on Feb 13, 2008
  • 1586 Answers
SOURCE: Can I use a 2
Doubtful - the factory head unit isn't meant for 2-ohm operation and will stand a chance of damage.
Posted on Jul 31, 2008
  • 4345 Answers
SOURCE: My reciently purchased Basslink is
Run the ground back to the battery. The body is not a good enough conductor.
Posted on Feb 24, 2011
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Infinity Basslink not producing any sound. Green light on.
check that fusse under the hood if its blown pull it out and replace it wont hurt anything if u pull it out an put it back in if the cars off.but if ur getting power lights on the amps then more then likely ur fuse isnt start by checking the audio cables are produceing sound.if u need more help let me know
Sep 29, 2009 | Infinity BASSLINK Car Subwoofer
04 Acura TSX Navigation System trouble
most of the time the disc is bad but when the disc goes bad its the navi unit that causes that to go bad so if you replace just disc will need another one soon after recommend replacing unit or ship to repair facilty for repairs
Apr 23, 2009 | 2004 Acura TSX
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Jun 24, 2008 | Infinity BassLink II Car Subwoofer
Feb 02, 2008 | Infinity BASSLINK Car Subwoofer
Basslink II problem running off speaker input
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
Dec 12, 2007 | Infinity BassLink II Car Subwoofer
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Infinity BassLink II Keepps Cuting Out!
Auto cut is due to overload, check out the wattage handling capacity of the Amp & the woofer( if the impedence is too low there will be an over load for the Amp.
May 06, 2007 | Infinity BassLink II Car Subwoofer
Infinity BassLink II Car Subwoofer Logo
179 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
