Question about Belling SGE12X Front Load Washer / Dryer
My Belling integrated washer drier will tumble ok but there is no heat. Is this easy to fix?
  • Belling Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 30, 2010
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Hotpoint ctd80 tumble drier drum not moving but still heating up
yes it will b the drive belt and its a easy repair.
Jan 17, 2012 | Dryers
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
My zannussi TD4113W tumble drier has stopped tumbling .It still is heating up ok .Can I fix it ?
it sounds like the belt has broken or the motor has burned out try starting there
good luck
May 15, 2010 | Zanussi TC7114W Electric Dryer
No heat in tumble drier - I've changed the two stats and the heater
First cleaning out the vent inside and also your hose vent. If its old, replace it with new one. Cheap and easy so far. Second could be a bad gas valve or solenoid coils. Valve should be replace by a licensed repair person. Could be pricey. If its the solenoid coils it's a cheaper easy self fix.
Dec 04, 2009 | Whirlpool Dryers
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Jun 05, 2009 | Kenmore Dryers
Belling SGE12X Front Load Washer / Dryer Logo
110 people viewed this question
Top Belling Washing Machines Experts
shaun taylor
vince
Kolbrun...
Are you a Belling Washing Machine Expert? Answer questions, earn points and help others
