My LG monitor L1753S won't open...is it the power supply of the monitor or what?? and how ro open it...
  • 17,130 Answers
If you meant that the power supply is not working it is fault in the smps:
so check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Sep 30, 2010
LG FLATRON L1753S switching power supply 12dc not working
Plug in the AC ADAPTOR OR CHARGER AND TRY TO SWITCH ON if it runs then your battery is damaged if not then the laptop is damaged
Apr 26, 2014 | Computers & Internet
I have no driver for my lg flatron l1753s monitor, where can i download the driver???
If you want drivers for lg just click this http://members.driverguide.com/driver/detail.php?driverid=983449 then choose the driver you want. Hope it will helps you
Jul 11, 2011 | Computers & Internet
LG Flatron L1753S very bright LCD display how do i remdy this please kindly thank you
You can adjust the brightness with the on screen display controls. This link will get you the manual.
May 02, 2011 | LG Flatron L1750S 17" LCD Monitor
My lg flatron l1753s shows some visual disturbnce like somthing flowing and in few moments shows completely black screen after that normal so......plz tell me what to do to fix it?
It could be the domestic maintenance problem keep your monitor away from moisture and other physical damage it will make your monitor perfect as new working...
Dec 09, 2010 | LG Flatron L1750S 17" LCD Monitor
My computer wouldn't start and it is stuck in power saving mode. its LG flatron L1753S.
check the power cable, make sure you are using the correct video cable and input source and it may help if you try to use a different power cord that is confirmed working. if you use an adapter for it, verify that the adapter is working.
Dec 04, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron 575MS 15.1" LCD Monitor Need 24 volt power supply
alkarim 15, Are you looking for an "open frame" switcher or a "open frame" linear dc supply. Does it need to have regulated output or if linear type just brute force output.What is the current requirement of the circuit you will use with the power supply? Have you checked www.jameco.com or www.digikey.com or www.newark.com . Does it need to be AC or DC output? 12fixlouie
Aug 27, 2010 | LG Flatron 575MS 15.1" LCD Monitor
LG Flatron L194WT Monitor no power
It can be as simple $5 worth of caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 27, 2010 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1753s is not working what will be the reason
90% LCD monitors failures are caused by bad caps.
Please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | LG Flatron L1750S 17" LCD Monitor
How to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
LG L1753S 17
If you keep any magnetic/electro magnetic objects near the monitor these kind of problem may occur, Example Speakers, mobiles.etc.,
But in you case, i hope the problem is with the hardware, Please change the Main Filter capacitor in SMPS of your monitor.
Note: It is not advisable to open the cover of the Monitor. Monitor and TVs stores power even they are disconnected so if you are not sure, please get help from a Service Engineer.
Sep 09, 2008 | Computers & Internet
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
