Question about Mozilla Firefox
What is troubleshooting which troubleshoot used in windows-xp.name it
  • 1,472 Answers
Satish_ya805
If you are having trouble with Firefox working properly alot of times all you need to do is just do a manual uninstall and reinstall of Firefox. The link below will help you do this.
http://www.fixya.com/support/r4215290-manually_uninstall_mozilla_firefox
Let know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 30, 2010
I use on my PC (Acer/Compac) My Pictures/Adobe Photoshop for the pictures I have. I have gone into the Properties section to add more information on each individual pictures. I than burned the photos...
  • When you go to the Connect to Server dialog, you may browse the names of computers that are on your local subnet.
  • You can connect to a server via its IP address or DNS name. If it is required or more convenient in your environment, you may also use other valid URL formats, such as:
    smb://ServerName/ShareName smb://DOMAIN;User@ServerName/ShareName
  • The name of the "share" (the shared disk, volume, or directory) must be specified. You will not be prompted for it.
  • You cannot type spaces as part of the share name when connecting. In place of any space in the share name, type: %20 .
  • When troubleshooting a connection issue, you can ping the IP address of the Windows PC using the Mac OS X Network Utility application (in the Utilities folder). A successful ping verifies a TCP/IP connection between the two computers. This is an important first troubleshooting step when there's no response or a timeout for a connection attempt, since SMB connections involving a Mac require TCP/IP. However, a successful ping does not mean the SMB service is also working or available.
  • Check Microsoft support resources for information about setting up file sharing on your Microsoft Windows-based computer. These may include Help files installed on your PC or the Microsoft online Knowledge Base. For example, see this article for Windows XP information: How to use the Simple File Sharing feature to share files in Windows XP.
  • When troubleshooting an SMB connection issue, use Console, which is located in the Utilities folder. These Console logs may help advanced users identify an issue: private/var/log/samba, private/var/log/kernel.log, system.log . Note that some log files only appear when logged into Mac OS X with an administrator acccount.
  • If you are connecting to Windows XP, make sure that the Internet Connection Firewall settings are not interfering with your connection. SMB uses ports 137, 138, 139, and 445. These ports should be open on the Windows XP computer. This may require "Advanced" configuration of the XP firewall.
  • If you are connecting to a Windows SMB resource, check to see if the firewall is blocking TCP ports 137, 138, 139 and 445. After trying the above steps, you may perform advanced troubleshooting by inspecting log entries in the Event Log of the Windows SMB resource (if you have access to it), and/or the Mac OS X computer's relevant logs in the Console application. If those steps do not help identify the issue, or you do not want to perform advanced troubleshooting, than you should contact your network administrator. It may be necessary to contact your network administrator in some situations in order to grant access to your Mac from the SMB resource, or its host network configuration.
  • Mac OS X uses SMB only over the TCP/IP protocol, not the NetBEUI protocol.
Dec 29, 2010 | Compaq Computers & Internet
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
I'm trying to run my Hypertech ECON programmer for my 2010 Silverado, when I install the disk it gives me a error code 2869 and exits me out of the install. Am running WIndows 7
It seems that Windows 7 is not compatible with this program and thus the error 2869.
1.run the program in the Program Compatibility Assistant utility in Windows 7.
then select the caption that says it ran on a previous Operating system ( that is Windows XP/ Vista etc. and select the radio dial to the left and click apply.
Instruction from Windows help:
Run the Program Compatibility troubleshooter
Click to open the Program Compatibility troubleshooter.
Sep 25, 2010 | Computers & Internet
No audio sound in my pc how to get back sound ?
Welcome.
Check if the sound driver is installed and up to date, follow these steps to find that.
Step 1:
  1. Click Start and then click Run.
  2. Type devmgmt.msc in the Open box, and then click OK.
  3. Check for Audio and if you see any yellow exclamation next to sound then either audio drivers are not installed or it needs to be updated.
Step 2:
To check manufacture try this.
  2. Type dxdiag in the Open box, and then click OK.
  3. Click the Sound tab.
  4. Under Device, look for Name, and under Driver, look for Provider.
  5. Click Exit.
Contact the manufacturer of the sound driver to request an updated sound driver.
If you dont see any problem with device manager (Step 1)
try below steps
Step 3: Use the Windows XP Sound Troubleshooter
loadTOCNode(2, 'resolution'); Windows XP includes a troubleshooting program which could help you resolve your sound issues. Start the Windows XP Sound Troubleshooter automatically or manually and then answer each question on-screen in order to try to find a resolution.
Start the Sound Troubleshooter loadTOCNode(3, 'resolution'); If you are already familiar with Windows XP Help and Support Center, click the following link to start the Sound Troubleshooter:
Sound Troubleshooter (hcp://help/tshoot/tssound.htm) OR
Start Sound Troubleshooter manually by using the following steps:
  1. Click Start, and then click Help and Support.
  2. Under Pick a Help Topic, click Fixing a problem.
  3. In the navigation pane on the left, click Games, sound, and video problems.
  4. In the topic pane, on the right side, click Sound Troubleshooter.
Step 4: Update your Media Player software
loadTOCNode(2, 'resolution'); If the sound problem that you are experiencing occurs when you use a media player such as Microsoft Windows Media Player, try updating your media player software. To obtain the latest version of the Windows Media Player, visit the following Microsoft Web site:
http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx (http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx) Determine whether you can now hear sound. If you can hear sound, the issue is resolved.
Regards,
Chandra Shekar G
PCS365.10
Bangalore.
Aug 02, 2010 | Microsoft Windows XP Professional for PC
RCINT failure.string table ID not found.'42' at line 462.
  • Something you have running in the background is failing. Googling around shows one person who had installed Style XP and that was causing the problem. Other links show people having the problem but no solution. So if you haven't installed Style XP, you'll need to do some systematic troubleshooting.
    The First Question Of Troubleshooting: If the problem is new, what changed between the time things worked and the time they didn't?
    The Second Question of Windows Troubleshooting: what is the malware/virus status of the machine? If you think it is clean, what programs (and versions) did you use to determine this?
    Be sure the computer is clean:
    http://www.elephantboycomputers.com/page2.html#Removing_Malware
    If the computer is completely virus/malware-free, manage your startup to find the culprit.
    Start>Run>msconfig [enter]
    This brings up the System Configuration Utility. Look on the Startup tab and find the probable culprit. Uncheck the box next to its name, Apply and OK out. You don't need to restart immediately, but the next time you do you'll get a dialog saying you've used the Utility. Just tick the box that says in effect, "don't bother me about this again".
    How to Troubleshoot By Using the Msconfig Utility in Windows XP - http://support.microsoft.com/?id=310560
    The free Autoruns program is very useful for managing your Startup - http://www.microsoft.com/technet/sysinternals/default.mspx
MS-MVP - Elephant Boy Computers - Don't Panic!
Jun 25, 2010 | Microsoft Windows XP Professional
Low sound
Method 1: Try another sound device loadTOCNode(2, 'resolution'); If possible, plug a different output device into the computer. For example, if you have been using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the device itself.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original output device and the issue is resolved. If you cannot hear sound, plug the original output device back into the computer and go to method 2.
Method 2: Use the Windows XP Sound Troubleshooter loadTOCNode(2, 'resolution'); Windows XP includes a troubleshooting program which could help you resolve your sound issues. Start the Windows XP Sound Troubleshooter automatically or manually and then answer each question on-screen in order to try to find a resolution.
Step 1: Start the Sound Troubleshooter loadTOCNode(3, 'resolution'); If you are already familiar with Windows XP Help and Support Center, click the following link to start the Sound Troubleshooter:
OR
Step 2: Use the Sound Troubleshooter loadTOCNode(3, 'resolution');
  1. Click the option that describes the problem that is occurring, and then click Next.
  2. Repeat step 1 until your problem is resolved or until you have reached the end of the troubleshooting path.
    Note You can click Back at any time to repeat the last step, or you can click Start Over to start the Sound Troubleshooter again.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 3.
Method 3: Update your Media Player software loadTOCNode(2, 'resolution'); If the sound problem that you are experiencing occurs when you use a media player such as Microsoft Windows Media Player, try updating your media player software. To obtain the latest version of the Windows Media Player, visit the following Microsoft Web site: http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx (http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx) Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 4.
Method 4: Update sound drivers loadTOCNode(2, 'resolution'); Out-of-date sound drivers may cause sound problems. Check whether an updated sound driver is available. You can use Microsoft Update to help you determine your current sound driver and if an update is available. Then contact the sound driver hardware or the computer manufacturer to request an updated sound driver.
To find out whether applicable driver updates are available, visit the following Microsoft Windows Update Web site: http://update.microsoft.com (http://update.microsoft.com) If the sound driver is out of date, follow these steps to find the name and provider of your sound driver:
  5. Click Exit.
For information about your hardware manufacturer, visit the following Web site: http://support.microsoft.com/gp/vendors/en-us (http://support.microsoft.com/gp/vendors/en-us)
Regards,
Pcs365.8
Jun 22, 2010 | Microsoft Windows XP Home (vis-winxph) for...
Troubleshooting wireless home network using windows xp
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
  1. Click the Start button, click Network Connections, and choose Show all Connctions.
  2. Click the Wireless Network Connection icon with your right mouse button, then choose View Available Wireless Networks.
  3. Choose the name of the 2Wire access point from the Available networks list.
  4. In the Network key field, type the hexadecimal key to access the wireless network.
    Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
  5. In the Confirm network key field, type the hexadecimal key to access the wireless network again for confirmation.
  6. Click the Connect button.
Apr 15, 2010 | HP Pavilion m7680n PC Desktop
Not printing, only going to 44% "preparing file print" is all it says
Please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
Oct 19, 2009 | Lexmark X4650 InkJet Printer
Can not install a lexmark 5000 to my computer
Oct 02, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Windows xp
Hi!
You may visit these sites for windows troubleshooting:
http://www.mvps.org/winhelp2002/
http://www.5starsupport.com/faq/xp.htm
http://freepctech.com/pc/xp/xpindex.shtml
http://www.kellys-korner-xp.com/xp.htm
Cheers!
Dec 12, 2008 | Microsoft Windows XP Professional With...
Mozilla Firefox Logo
Top Mozilla Computers & Internet Experts
Lesley Cameron
Lesley Cameron
k24674
Are you a Mozilla Computer and Internet Expert? Answer questions, earn points and help others
