Question about Toshiba E-Studio 3511 Color Copier
Estudio350 with error c010, checked the fuser, drum unit , dev unit, all are turning freely, error comes on as soon as fuser comes to full temp
Yes i do like that but it still not running, How can i do next?
Posted on Jul 08, 2013
  • 4,323 Answers
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Posted on Sep 30, 2010
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
i hope its L4.If it is showing
L4 it means the main motor is locked(failing to move) Check all the moving parts including the drum unit, developer unit, main drive unit and fuser unit if they are moving freely. If they are moving freely change the main motor
Jun 18, 2014 | Sharp AR-5320 Black and White Copier
Error code F-26-1
Is the devoper unit turning? Wipe the mag roller clean & power up, is the roller covered again by dev/toner, if not, it's the dev motor that's failed. Have you checked the toner recycle unit at the back? These get blocked , so no toner gets into the dev unit, is the m/c noisy, check the drum recycle unit isn't blocked.....is the toner bottle turning....
Oct 28, 2013 | Office Equipment & Supplies
Call service c010
Hi and welcome to FixYa.C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Thanks for choosing FixYa,
Aug 12, 2012 | Toshiba E-STUDIO 450 Copier
C010
Hi and welcome to FixYa. I am Kelly. C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Kelly
Nov 04, 2010 | Toshiba E-STUDIO 450 Copier
Magicolor 2300DL Printer. Blank pages come out. No error message. Toner and Drum are OK
here is my thinking... toner... goes from toner container... via developer to drum... where it gets info and then to paper where it gets placed... and then to fuser where it gets cemented...
if pages are coming out blank... check if toner is full... then check if developer unit is turning... then check if there is an image on the drum... if no image on drum then the charge roller or charge wire is not working....
if you still think all is ok up to this point then check your fuser... if it is cold after your machine is on for five minutes then its blown...
thats how I would check it...
Mar 12, 2010 | Konica Minolta magicolor 2300DL Laser...
Error c010
The main motor is bound up, not turning, Check and see if there is paper in the fuser or if you can turn the rollers
Dec 21, 2009 | Toshiba e-Studio 232 Black and White...
What does code: DK means?. How can I fix it?
This code indicates that the Black Drum has reached 100k. It could also be the black developer and primary transfer belt are at 100k.
DC = Drum Cyan
DM = Drum Magenta
DY = D
rum Yellow
DK = Drum blacK
Even if it is reset you will still need the drum unit or drum/mc kit replaced very soon. These units do not last much longer than specified. After this the print quality deteriorates rapidly. Eventually the drum edges wear away so much that they can force developer out of the dev tank. You can usually get away with not replacing the K dev. If you reset the K dev at the same time as replacing the K drum unit, the machine adjusts itself can function normally. A dev normally lasts 200-300K. The primary belt unit lasts longer than the 100K spec and often beyond 200K out of them before replacement or refurbishment.
Finally, make sure that the Firmware is up to date.
Sep 30, 2009 | Sharp MX-3501N All-In-One Printer
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
Printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Dec 31, 2007 | Kyocera Mita FS-1920 Laser Printer
Toshiba E-Studio 3511 Color Copier Logo
536 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
