Question about IBM NetVista PC Desktop
How to get a new driver installer
My friend reformat his IBM desktop and he use a XP os w/out using the system Recovery Disk. After he reformat, the PC is not rading the LAN Card, and Sound Card. What he need to do to re install that, he try to re install the system recovery disk but still his LAN card is not working. What is the best action that he can make?
Thank you very much!
  • akhilesh kandhari
    akhilesh kandhari May 11, 2010
    kindly provide the ibm desktop model number
The mdl is IBM Netvista X31
Posted on May 26, 2008
    Sergeant:
    Champion:
  • 326 Answers
Using another pc, download the driver for the model of LAN card used. Goto the control panel - system - device manager and unistall the card (keep hardware attached to pc) and reboot. Use the downloaded driver to reuninstall. When it gets back online, do the same thing with any other device not working. Be sure to get the drive for the operating system used.
Posted on May 25, 2008
Had dual boot with linux, lose my XP. I have the 5 cd recovery disk, but I can not install my XP back.
  • Hello charlieri_1, this happens often when installing 'new' OS, especially when creating a "Dual Boot." What you will have to do is a "Clean Install" starting from scratch; unfortunately! You will have to use the "Recovery Disk" to install Windows XP, first! Next, after you have restore the XP [OS]; then you will install the more "Updated" OS, [Linux] "This is just the Operating System way of order; oldest first, latest last, to properly install the OS. Hope this helps you, thanks paul7of9."
Dec 17, 2010 | Acer Aspire T135 PC Desktop
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
When i start it up, only the "vaio" is occuring on my screen. i tried to reformat it using xp sp2, but it doesn't working. what should i do
In that case, put your Windows XP disk in the drive and boot up. During boot up press F2 and set the boot sequence to CD. Windows will install XPon your hard drive. Follow the promps and after the istallation is finished, download and install SP3.
Apr 01, 2010 | Sony VAIO NS Series VGN-NS130E/W Notebook
P 3 with 256 sd ram,not able to install xp
It is struggling to install a driver. reformat the hard drive when you have the option (Fat 32 or NTFS which is better) and try again. If it still fails then remove usb devices except for keyboard and mouse if they are usb. Remove and add on cards and install on a basic system. If the install still fails then you have a corrupt hard drive or corrupt install disk. you can start the computer using the install disk and selecting recovery console to give you an dos screen. At the prompt type chkdsk and let it look for errors.
Jan 06, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
Cant reformat C:\ to re-install XP.
Install XP using a CD and start the setup from CD
when you are asked to do something on your harddisk, first you delete existing partition and create new partitions, then you do a full format.
hope this will solve your problem.
Note : Boot your system from Windows XP Installation CD / Restore CD
Jul 25, 2009 | Computers & Internet
Hp Pavilion 6701 desktop with ME. Installed Xubuntu OS and removed ME. Want to reinstall ME but recovery disc won't work.
Hard disk needs to be reformatted--start machine and press correct key when "setup" appears in first dialog. Remove hard drive in first screen, then reinstall. Restart computer, should now say: "operating system not found". You need original Microsoft OS disk to reformat drive and reinstall ME. All previous information on hard disk will be lost with this procedure. Recovery disk is used with original OS before Ubuntu. If you don't have original MS disk, suggest going to XP.
Jul 06, 2009 | Computers & Internet
IBM NetVista 6790 31u - Need to reformat single HD computer.
The PC comes with a restore CD. This to reinstall or repair your OS which is a genuine copy(look for the sticker)Use te restore CD while startup and follow the instructions...........sodeep
Apr 07, 2009 | IBM NetVista PC Desktop
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
How to reformat R52 ibm thinkpad
Your laptop should have come with a recovery disk, you will need to boot to that disk following the onscreen steps for formatting and restoring the operating system files. Furthermore, if your system did not come with a recovery disk, or you have a Windows XP/Vista disk you can boot to that instead.
Windows XP Install:
After the installation system boots, the setup prompt will prompt you for searching the system for previously installed versions of Windows; bypass the recovery option after the search is complete. The setup will then display a list of Hard Drives to install Windows; follow the key for deleting the partition (press "D" to delete). Once the partition has been deleted highlight the "free hard drive space" and press "Enter" then you will be prompted to format the drive and install Windows. Moreover, you should right down the Windows Product Key off the sticker on the bottom of your laptop; you'll be asked for that key after the setup restarts your computer assuming you are using that license for that version of Windows.
Windows Vista Install:
When you boot to the Vista DVD you will be prompted to enter the product key as soon as the setup loads. Select the Hard Drive with the mouse, then left-click the format button on the right pane. Continue with the installation.
Nov 29, 2008 | IBM ThinkPad R52 Notebook
IBM NetVista PC Desktop Logo
160 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
