Question about Panasonic Televison & Video
My plasma tv keeps on blowing the fuse? any idea why?
  • Panasonic Master
  • 17,130 Answers
This can be a fault in the SMPS , a faulty Smdriver or a storage capacitor , if this section alone is powered it can be confirmed. If not there can be heavy drain in the mother board or a possible short in the drivers or power capacitors.
Check this link for SMPS tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Sep 30, 2010
  • 901 Answers
Check SMPS circuit.
Check whether any diode is shorted itn the supply line. Start from the AC line, diodes, capcitors. Check SMPS Transistor mounted on heat sink.
3 Suggested Answers
lovejoy91
  • 691 Answers
SOURCE: Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Posted on Mar 08, 2011
  • 132 Answers
SOURCE: My dell 50" plasma tv had a blown 8amp fuse on the
Replace the power supply board.
Posted on Aug 23, 2010
Samsung Plasma 64 inch, was on, then blew house fuses and no longer works. Isolated TV to work out that this was the problem. Any ideas
Dont turn on any more these have SMPS in them an it looks like yours has failed. You can try to replace them but sometimes when they blow they take out other boards. You need to find a repair person in your area that does this kind of work. You can place where you bought it or other tv places an ask where they recommend. In my area there are none. Drove 30 miles to get one. This is one reason I did not get plasma, they are expensive an few parts to repair now. I hope it works out for you.
Jan 29, 2015 | Samsung Televison & Video
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
Free tv troubleshooting
probably needs one or both of the sustain boards, i would invest a little money and have a professional check and diagnose it, I feel this presents to big a problem for the layman.
Jun 20, 2013 | Panasonic Televison & Video
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
The new fuses keep blowing
Are you referring to the power supply fuses or the fuses on the Ysustain/Zsutain boards?
Jan 15, 2013 | Vizio VP422 42 in. Plasma TV
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Keeps blowing the plug fuse and/or triping the circuit breaker when plug in? Been working fine for 5 years until now
That must be the mains cable or the filter box as it enters the TV.
The TV is fused internally so suspect the supply cable or mains filter capacirors.
Hope that helps.
Dec 10, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Fuse blown on incoming power replaced fuse but no luck
replaced the t8ah 250v fuse and it still blow when i turned on the tv
Oct 19, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
Televison & Video Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
