Question about Husky Wet Tile/Stone Saw with with Laser and Stand
Need parts for husky tile saw THD750l need bolt fence
Hi, Take a look at amazon for replacement parts: Amazon com Husky tile saw. Hope this was helpful. cheers
Posted on Nov 29, 2014
5 Suggested Answers
  • 1335 Answers
SOURCE: I need the guide/fence for the husky THD750L.
You can order the parts at
http://www.huskysupport.com/products/product.aspx?ID=5
Please rate this solution.
Posted on Sep 23, 2010
SOURCE: husky wet tile saw repair service
I need to order a part for my Husky wet tile saw. can someone give me an email address. web serches are a bust.
Posted on Dec 17, 2009
  • 25 Answers
SOURCE: tile saw thd9501 Husky I need a parts
Grinder/motor assembly is sold as a complete unit only. The cost is over $129.00. My opinion, scrap it, but one at Harbor Freight (get the lifetime warranty (just a few dollars more), any problems, they replace the unit wiht a new complete saw. The quality is no worse than the Husky you own now.
Posted on Feb 11, 2010
c1apton15
  • 3400 Answers
SOURCE: I need a owners/parts manual
try here ->http://www.huskysupport.com/files/thd950usermanual.pdf
Posted on Apr 04, 2011
I need a replacement fence for a Husky THD 750L tile saw where might I find one?
http://www.fixya.com/support/t16308541-husky_thd_750l_replacement_guide_fence
Apr 27, 2017 | Saws
Huskey tile saw thd950l motor how much would it cost motor #c5d41884?
Take a look on amazon for sure. Amazon com Husky tile saw. If cant find just a motor, for sure there is someone to answer that question (someone who sells husky saws...). I hope this was helpful. cheers
Apr 12, 2011 | Husky Wet Tile/Stone Saw with with Laser...
I need a owners/parts manual for a husky TDH950L tile saw
Apr 04, 2011 | Husky Wet Tile/Stone Saw with with Laser...
I need the guide/fence for the husky THD750L. Where can I find it?
The problem is that the threads are stripped inside the handle on the rod.Take the cap off the end of handle & remove the rod and 6m nut.You can fix the fence for less than 6 bucks. Get a 6m threaded rod ($3) 1 meter long. Buy a small bag of 6m nuts(.68) & bag of 6m locking nuts(.68). Cut the threaded rod to about 20" and run 2 nuts down about 3/4" to lock them. Now put the nut in the handle & replace the cap. Run the rod though the spring & flat piece until it comes out the other end. Now put a washer & locking 6m nut on the end. Washer has to be big enough to prevent locking nut from pulling through. Hope this was clear enough. I made 2 of them after I figured out what the problem was. A new fence runs about $25 if you can find them. I love this tile saw & have used it on many jobs because it's light & portable. John in NJ
Sep 23, 2010 | Husky Wet Tile/Stone Saw with with Laser...
MY SWITCH WENT OUT ON MY TILE SAW WHERE CAN i GET
You can get the part from husky website at:
http://www.huskysupport.com/products/product.aspx?ID=4
From there scroll down till you see part number
6102018
switch Knob for $5.38
Hope this is what you are looking for
Nov 30, 2009 | Wet International Husky 7" Wet Tile Saw...
The wet saw husky thd 950l wore out yhe bearing and make
I am a contractor who has used this saw for about four years. I just ordered the new motor for $79. The Husky has been a great saw. Don't waste your money buying some junk for Harbor Freight.
Oct 14, 2009 | Wet International Husky 7" Wet Tile Saw...
I have a husky thd950L wet tile saw and the on/off switch broke. Where can I find a replacement part?
I need to replace the ball bearings in my Husky THD950L tile saw. Please tell me where I can find them.
Oct 08, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Husky wet tile saw repair service
Aug 24, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Husky Wet Tile/Stone Saw with with Laser and Stand Logo
3,436 people viewed this question
Top Husky Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husky Measuring Tool and Sensor Expert? Answer questions, earn points and help others
