Question about Strategy First Disciples 2: Dark Prophecy for Windows
I have just installed Disciples2 rise of the elves but when i double click on the shortcut nothing happens ...ditto while i tried to execute the .exe file
    New Friend:
Maybe you got a problem to your registry. cleaned it up or just re install the game
Posted on Mar 25, 2014
4 Suggested Answers
SOURCE: the sims 2 double deluxe_code
apo ellada den eis?? akou. ama exeis k allo game sims prepei n t kns delete k meta (egw ekana epanakinhsh)t egka8istas. meta egka8hstas k ta alla. dokimase. elpizw n voh8hsa.
Posted on Dec 23, 2008
  • 423 Answers
SOURCE: I click the exe/shortcut and nothing happens it doesn't launch. I had it before but i deleted it and now installed again. It worked back then but know it doesnt.
check if you have correctlu instaled the game and put the crack also check if your computer can turn it or not
good luck ^^
Posted on May 29, 2009
  • 107 Answers
SOURCE: i click on the shortcut
First uninstall and reinstall the whole game. Then make sure you have the latest patch V1.06. If that does not help here are good instructions for installing AND running the game as administrator and with compatibility mode (if you are running Vista or Win7:
http://www.ataricommunity.com/forums/showthread.php?t=659761
This also has helped to solve a lot of issues:
http://www.ataricommunity.com/forums/showthread.php?t=455721
Posted on Sep 02, 2010
How do I use a program ive just downloaded on this laptop
Hi
Usually the files you download for programmes are ".exe" or ".zip" files. In the case of ".exe" files they are either executable, in which case you need to double click on them and follow the instructions to install the programme, or they are self-extracting zip files where you again double click on the programme, it will ask you where you want the files expanded to, and once expanded you need to find the "Setup.exe" file and double click to install the programme. ".zip" files you have to expand manually and then double click the Setup.exe" file to install the programme.
Incidentally you must have administrator rights to install programmes, if you are a standard user, most likely, then you must either run the programmes as administrator (right click on the file and click "Run as Administrator" in the menu that comes up) or log off and log on as an Administrator with appropriate password.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | ASUS X53E-RS52 15.6" Laptop Computer,...
Tip
How can I run two Skype accounts on the same computer?
To use more than one Skype account on the same computer at the same time you need to start a new instance of Skype.
1.
From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
2.
In the Run window, enter the following command (include the quotes) and press OK:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get an error message, copy and paste the exact command from this page and try again.
Be aware that if you have changed the installation path for Skype then you will need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
1.Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
2.Right click on it and select Send to > Desktop (create shortcut)
3.Locate the shortcut on the desktop, then right-click on it and select Properties
4.In the Target field, add: /secondary. The Target field should now be "C:\Program Files\Skype\Phone\Skype.exe" /secondary
5.Click OK. You can now start a new instance of Skype every time you double-click the new shortcut.
on Nov 19, 2013 | SKYPE Computers & Internet
When i click my fifa 13 icon nothing happen and game dznt start
The shortcut may be disabled or pointed in the wrong folder
locate where the game is installed in your computer C: drive > programs, the game folder and look for the game name with exe as the extension - double click > If the game launches then delete the icon on ur desktop - right click the .exe file and create shortcut on desktop. if it does not then u may have re install the game
Aug 23, 2013 | Electronic Arts FIFA 13
Cannot open Reader on Desktop - click the icon and nothing happens
If you mean Adobe Reader, then either the shortcut has lost the information on what file it is associated with or Adobe Reader is no longer on the computer. If you recently transferred to a new computer using the Windows Transfer Wizard, the shortcut may be pointing to a different version folder or to a not yet installed program. Remember the Transfer Wizard does not install the programs and doesn't transfer the registry information about installed software from the old computer.
For Windows:
First, right click on the icon and then click on Properties. That will give you the location and name of the program it is associated with (as it was created). For example: on my Win7 32-bit machine this reads "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe". Next open the Control Panel Programs list, see if Adobe Reader is listed. (For Win7, this is Start > Control Panel > Programs. WinXP, look for the Add and remove programs section.) Open Computer (My computer) and navigate to C:\Program Files. See if you have an Adobe Folder and then the reader folder location. (If the folder exists, check for the exe file and if that full folder name matches the one for the shortcut.)
If Adobe Reader isn't installed, go to http://www.adobe.com and follow the link on the right hand side to download and install Adobe Reader. Then remove the bad shortcut since a new one will be added to the desktop.
If you have Adobe Reader installed but the shortcut isn't pointing to the correct location, you can create a new shortcut by right clicking on the exe and choosing create a shortcut. Before you do this, double click on the reader.exe and check that it does launch. Otherwise, uninstall and reinstall the program.
I hope this helps.
Jan 12, 2011 | Computers & Internet
Removal of shortcut virus in pen drive
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
Sep 03, 2010 | Online Computers & Internet
I try clicking on the application and it won't respond
Start-->All Programs->Your application. If it works, create a new shortcut on desktop. If it does not work, the application has been uninstalled, or it folder has been displaced.
You can use Add/Remove program in control panel to verify if it is still installed.
To create shortcut, point mouse cursor in a free area, Right Click >>New>>Short Cut. Click the submenu. A create shortcut window appears and you use the browse button to travel to the application folder in Programs Files, and select the executable file (has an extension .exe) and click OK.
Hope it helps
Aug 31, 2009 | HP Computers & Internet
Computer wont read the software!!!
i think yur cd has been corrupted.. please take a fresh copy of a installation file and install it.
Jul 06, 2009 | Microsoft LifeCam VX-3000 Web Camera
Double clique on Icon but program doe'nt run. Have tried your solution given under FAQ , but it still dos'nt work.
Right click on the icon, select 'Find Target' then see if it leads to real executable, like *.exe, rather than just another shortcut, like *.ink.
Oct 15, 2008 | Computers & Internet
Not working
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Jul 26, 2008 | Microsoft Windows Vista Ultimate Edition
Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini).
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
Microsoftpowerpoint.exe
smss.exe
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
May 31, 2008 | Microsoft Windows XP Professional With...
Strategy First Disciples 2: Dark Prophecy for Windows Logo
108 people viewed this question
Top Strategy First Video Game Consoles & Games Experts
James Wishart
Are you a Strategy First Video Game Console and Game Expert? Answer questions, earn points and help others
